stage 2 turbo/ecu? - Page 2 - Subaru WRX Forum
post #16 of 22 Old 07-20-2006, 05:21 PM
awd>fwd's Avatar
Originally Posted by thatoneguy
I just installed a boost gauge and max boost is 12.5psi @ 4500, then it drops to 10psi on it's way too 7000. Does this sound right for a stock turbo?
What gear were you in? That sounds about right for 1st and 2nd gear, but is WAY too low for a stage 2 in 3rd or 4th gear.
Brent
awd>fwd is offline
post #17 of 22 Old 07-20-2006, 06:43 PM Thread Starter
I just made a test run up the street through 1st and 2nd is all. After I drive to work and back tomorrow I will let you know.
thatoneguy is offline
post #18 of 22 Old 07-20-2006, 06:47 PM
awd>fwd's Avatar
The WRX (unless tuned otherwise) does not hit full boost in 1st or 2nd gear, probably to reduce blown trannies or wheelspin.
Brent
awd>fwd is offline
post #19 of 22 Old 07-22-2006, 12:17 PM Thread Starter
I am now hitting 14psi @ 4500 in 3rd, 4th, and 5th
post #20 of 22 Old 07-22-2006, 12:19 PM Thread Starter
My guess is that it doesn't have enough drag in 1st and 2nd gear to reach full boost.
post #21 of 22 Old 07-22-2006, 02:04 PM
JiveMasterT's Avatar
You exhaust gas and pressure comes in proportion to the amount of work your car has to do. The higher the gear, the more exhaust gas pressure since the motor has to work more. I'm over simplifying this here but just imagine imagine blowing on a pin wheel... if you blow on it gently it will spin a little bit, but if you blow with all of your might then it spins really hard. In 1st and 2nd you may not be blowing hard enough to make it spin all the way.
If you're using the cobb then they have maps for those who are not able to reach full boost... might want to send them an email.
Patrick - 2007 STi Limited
▼SbiΣ Mi▼
JiveMasterT is offline
post #22 of 22 Old 07-23-2006, 08:40 AM Thread Starter
I don't have any engine management. My wife is in school for another 9 months, so money is tight until then. My next big purchase will be a COBB accessport or a utec.
Thanks for the help.
