-   -   Stage 1 -14.2psi.... (http://www.wrxtuners.com/forums/f52/stage-1-14-2psi-28105/)
pimmeh 02-04-2010 02:59 PM
Hey everybody!
Im moving quickly through the modification check list and i was hoping to find out weather or not i'm on target! As theres no better sourse of knowledge and expirance here i am! so the car is an 04 WRX with a K&N typhoon and a greddy 3" Catback i recently installed my AP (stage 1 91oct) and she's haulin some ass!! i'm making 14.5 psi at full boost.
Now i have a Invidia catless up and a HKS catless down ready to be installed when ever i pull the trigger... buuut!! i would like to make sure i'm on target for the proper numbers as i've read that running more than 15psi on the stock turbo becomes a bit risky and i'm pretty much there after the Stage one..
So you guys think this is right were i should be? have any of you ran similar numbers with similar mods? should i go ahead and go catless?? or are there some issues i should know about before i pull the trigger!!
Any and all feed back is welcome!
Thanks boys!
hahahah ps this is friggen awesome--->:beatentod
RcrsWetDream 02-04-2010 04:58 PM
1 Attachment(s)
I haven't heard of any issues running more than 15 psi on the 04's. If I'm remembering correctly the COBB Stage II will push you up to 16.5 psi, Stage I is around 15 +/- a bit. You're on target right now and Stage II won't be a big strain on the car. Tons of guys here are Stage II and higher.
pimmeh 02-04-2010 05:59 PM
i am liking what im hearing!!
newtothegame 02-04-2010 08:11 PM
My stage 2 on my 07 was around 17-18PSI, not a single problem at all. When I pulled my stock turbo off for upgrade, my shop said I had one of the cleanest used turbos that they had ever seen. Granted I only ran stage 2 for about 6-7 months and never beat on the car too much either.
blk05WRX 02-05-2010 04:50 PM
Let us know what gear you're in when you hit 14.5. For me, first and second gear are around 14.5-15. Third and 4th is where the boost climbs to the target 16.5.
pimmeh 02-08-2010 03:17 PM
first and second gear i boost to about 13.8psi and in thrid and fourth i boost to about 14.4-14.7psi but this is still stage 1
cooperwrx 02-08-2010 09:19 PM
I'm running on my 04 about 15.3 at max boost in 3rd gear with about your set up plus i got my catless up and down on. im making 256whp and 249wtq with a tune and no turbo problems at all. (8months with this set up with out the tune) and ( about 2 month with the tune)
pimmeh 02-09-2010 11:37 AM
Beauty,
i appreciate the info guys, i really wanted to make sure i'm in the right spot before i moved forward.. i kinda just went and picked everything up all at once..ended up getting a better deal that way. i'm stoked as it gets tho..stage 1 was impressive...i'm thinkiin stage 2 we'll be serious!!
Kramericaa 04-10-2010 08:45 PM
I have a full turbo back, K&N SRI, and cobb stage 2 flash via the AP on my 02 bugeye. Like others have said, I get about 14-14.5 psi in 2nd and 3rd (don't even punch it in first because I'm afraid of breaking the gear, so don't know bout boost in that one). 4th and 5th gear I'm usually around 16.5 max boost, although the most I've recorded was 17.3 psi. O yea, and I have close to 100k on her with no problems! Yes I have a stock tranny with a heavy duty clutch that's been on for the last 50k miles. (Who said it had a glass tranny:nono:) Anywayz, don't worry about your turbo boosting to much, your engine is bullet proof, and even if you fry your turbo (which I doubt you will) upgrade to a bigger an better one.!Thumbs Up Careful with the launches though, tranny is the only thing ya need to worry about.
turmic 04-13-2010 11:11 PM
^Very bad info. The engine is not bullet proof. Negliance will kill any engine.
Kramericaa 04-14-2010 12:17 PM
[quote=turmic;243415]^Very bad info. The engine is not bullet proof. Negliance will kill any engine.[/quote]
I guess it depends how literal you take my statement (when I say bulletproof, I mean it's a solid engine). His orignal question stressed more concern on his stock turbo over boosting, which with his setup and stage 2 tune after the DP is put in, is NOT going to hurt the engine unless there are some unforseen problems. The real worry would be hurting the turbo if anything, but that's an easy and fairly inexpensive upgrade depending what you choose. My point is: if there is a strong part to a wrx, it's gotta be that little boxer (I don't think its the tranny). And I do agree, "negligence will kill any engine".
UnknownAlly 09-09-2011 03:43 AM
Preap Sovath thanks you all.
So how is the Stage 1? Is it a big difference? Enough to get you a better 0-60, 60ft, 1/4 mi ET?
brfatal 09-09-2011 07:39 AM
Stage 1 should not be considered a speed improvement, because it's not. It's a drivability upgrade. All it does is smooth out the powerband.
