So i have about $1,000 to spend... - Subaru WRX Forum
post #1 of 17 Old 09-09-2004, 09:04 PM Thread Starter
My05WRX is an unknown
Send a message via AIM to My05WRX
I have about a grand to put into my car. I am debating getting a front mount or a UTEC.
How much real power will the UTEC add? and how much would the FMIC add?
I am leaning toward the UTEC but I already have the GReddy Profec B spec II boost controller. Should I just get the SAFC?
I like the FMIC because of the look but I want power.
I have headers, boost controller, uppipe/downpipe, CAI, and catback exhaust.
I am running catless.
What should I spend my $$ on?
My05WRX is offline
post #2 of 17 Old 09-09-2004, 11:41 PM
hipo_wrx's Avatar
hipo_wrx is an unknown
Send a message via AIM to hipo_wrx Send a message via Yahoo to hipo_wrx
id say utec then sell your boost controller, from what ive read.... a fmic wont actually add power as it will to increase the saftey of raising boost to get power but i'd say with the utec you could easily tune more power than a fmic could add if so. than save for the fmic and buy a turbo upgrade kit you like.
just my 2 cents
hipo_wrx is offline
post #3 of 17 Old 09-10-2004, 02:53 AM
tescrex's Avatar
tescrex is an unknown
Send a message via AIM to tescrex
Utecs are sweet, check out the Cobb accessport ecu as well, not as tunable, but more foolproof. But dont upgrade to a fmic until you get a new few system (injectors and pump) as well as a new turbo. If you are planning on going that route, a utec would be more suited to you.
tescrex is offline
post #4 of 17 Old 09-10-2004, 08:13 AM
Cosmo's Avatar
Images: 15
Depends on how much further you want to go. Do you want to get a bigger turbo? If so, get a UTEC now. If you are satisfied with the stock turbo, I would get a re-flash and a cat-back.
Cosmo is offline
post #5 of 17 Old 09-10-2004, 09:21 AM Thread Starter
I am running catless right now. How much would a reflash cost?
If I got a UTEC would I have to get it tuned?
My05WRX is offline
post #6 of 17 Old 09-10-2004, 11:02 AM
Cosmo's Avatar
Images: 15
www.cobbtuning.com
I believe a reflash is $495.
Yes, you have to have a UTEC tuned. You can run their base maps, but they run very rich and have low boost.
Cosmo is offline
post #7 of 17 Old 09-10-2004, 11:03 AM
IBAUCLAPlaya's Avatar
Go UTEC. Sell your boost controller, and intake and try to get a catback. Then you will be at a stage 2.5 with about 230 to the wheels. You don't need to tune it, because it comes with a base map from TXS. But you can raise the boost if you want and adjust the other parameters on the UTEC to get more power for your specific car. A relfash is about 400 dollars.
IBAUCLAPlaya is offline
post #8 of 17 Old 09-10-2004, 11:16 AM
Cosmo's Avatar
Images: 15
You do need to tune it. That is, unless you like getting 140 miles to a tank....
Cosmo is offline
post #9 of 17 Old 09-10-2004, 11:26 AM
Do all of the base maps run that rich? I ran my stage 2 base map for about a hundred miles and I was fine on gas.
post #10 of 17 Old 09-10-2004, 11:48 AM
REXronald's Avatar
REXronald is known to be trustworthy and helpful REXronald is known to be trustworthy and helpful
tuning utec
w/out tuning that utec, you really won't know if your getting the full power potential (you probably aren't) of the utec.
we know stage 4 on the 4.2 revision runs pathetically rich, i don't know about the others of the new revisions, but they are really just intended as base maps to get you a good starting point... if you plan to learn the utec and tune it yourself, then you'll need a decent EGT gauge or a wideband O2 sensor to monitor your results and dial in the tune...
you shouldn't need a front mount until you have a larger turbo setup... unless you want it to just look cool... but i wouldn't personally want a front mount if i didn't have anything to back it up.
my 02
REXronald is offline
post #11 of 17 Old 09-10-2004, 12:20 PM Thread Starter
How much would it cost to get the UTEC tuned?
My05WRX is offline
post #12 of 17 Old 09-10-2004, 12:30 PM
REXronald's Avatar
That All Depends
dyno tuning ranges from $150-$200 per hour for a dynapack AWD dyno... probably take 1.5-2.5 hrs for tuning depending on what ya want.
cheapest route would be someone to road-tune the car with a portable wide-band hooked up to it... and a passenger sits with with Laptop. Of course, you could take the time and educate yourself and tune it yourself with an EGT gage, i know people do it... Cos has done it... but it takes a lot of time to get all the wrinkles ironed out and still no way to know for sure that you've tuned for every last little bit of power.
post #13 of 17 Old 09-10-2004, 12:38 PM Thread Starter
Ok thanks. I think I will go with the UTEC. Ive made $300 selling football tickets up here at UW so that should pay for the tuning.
Anyone know a good place with an AWD dyno in southern Wisconsin or northern Illinois?
Would adding a fuel pump help with power at all right now?
My05WRX is offline
post #14 of 17 Old 09-10-2004, 12:47 PM
tescrex's Avatar
I'm not sure, but I don't think the fuel pump is going to make a noticeable difference until you get a new turbo and injectors. But I could be wrong.
tescrex is offline
post #15 of 17 Old 09-10-2004, 12:54 PM
REXronald's Avatar
No
Pump is there to supply more fuel when you need it. you need it when you have a larger turbo supply more air flow and therefore the fuel is needed to match that addt'l airflow...
The only thing that truly creates more HP is buring a larger quantity of air and fuel in a specified period of time. in order to that numerous supporting mods are usually required... ie... the intercooler upgrade does not itself create power, it allows more air to flow through your system and it more effectively cools that air also... adding more air to a cylinder of the same size creates a stronger combustion.... but adding that air requires an increase in fuel also so as not to increase engine temps to much... that's why most will tell you once you get a bigger turbo, you will need bigger fuel injectors, fuel pump, and intercooler to go with it. turbos simply increase how much air can be burned in any 1 cycle of your engine. and the UTEC is the brain that tells your network how much air and fuel to supply, when to supply it, and when to ignite it with the spark plugs.
hope that helps.
