So, I'm a noob in the WRX world. I have an 05 Rex with stock everything except a Kartboy shifter. Nothing performace wise. I would like to upgrade my UP however living in SoCal I have concerns about smog. Has anyone in the SoCal area experienced any difficulties getting their Subbies smogged? Are the other two cats good enough to clean up the gasses and then all I have to worry about is the visual inspection? All help is greatly appreciated.
in california.. as long as you pass visual and you dont have a CEL all you'll have to worry about is passing the actual emissions.. and yes.. the getting a catless up pipe should be fine as long as you get the CEL fix for it. even a upgraded catted dp should pass emissions too..
