Old 03-23-2004, 09:35 PM   #1 (permalink)
Epyon08's Avatar
Car: 04 WRX
Reputation: Epyon08 is an unknown
Exclamation silicon hoses?????
I was wondering if adding silicon hoses to a wrx will add any hp gains for the car??? or anything else like better throttle response or acceleration like for example adding samco intercooler hoses on a stock turbo??? or perhaps adding a perrin or samco turbo inlet pipe??? in conclusion... are these better than stock?
Old 03-23-2004, 09:41 PM   #2 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
Well they are better and might yield a minimal gain - 3-4 hp, you might be able to notice on the butt dyno tho! Not really worth the money.
Old 03-24-2004, 11:28 PM   #3 (permalink)
Reputation: redtangent is an unknown
that's what i heard about them too. when i spend the money on a new intercooler i think it wouldn't hurt, they're supposed to more efficiently direct the air
Old 03-25-2004, 06:38 AM   #4 (permalink)
WRXblurr's Avatar
Car: 05 Evo MR
Reputation: WRXblurr is an unknown
also if you plan on running higher boost they wont crack.. the plastic pices tend to split at high boost levels..
Old 03-25-2004, 08:54 AM   #5 (permalink)
Car: 04 WRX
Trader Rating: (1)
A new intercooler comes with new reinforced hoses. If you plan on getting a new IC don't buy the IC hoses.
Old 03-29-2004, 12:55 PM   #6 (permalink)
Reputation: Sphinx1 is an unknown
I believe the turbo inlet may increase spool slightly.
Old 03-30-2004, 02:09 AM   #7 (permalink)
Reputation: mtskibum16 is an unknown
You may also experience a slight gain in throttle response. They are not really needed until you start raising boost. At the point that you start significantly raising boost however, you should get a new ic and thus get new hoses anyways. It's probobally not something you want to spend your money on esspecialy if you plan on buying a new ic in the near future.
I want a WRX!!!!!!
