Old 05-07-2008, 11:28 AM   #1 (permalink)
rubenc66's Avatar
Car: 04 WRX
Reputation: rubenc66 is an unknown
running rich
so i'm running a catless exhaust tbe and for some reason i've been smelling oil more than usual. I know that my car is going to be running rich since i have a catless setup but just wondering if anyones had same problem and what'd they do...
Old 05-07-2008, 11:54 AM   #2 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
Did you chk yur oil level....? Did you chk yur oil filter and plug ? Chk yur intercooler coupler from the manifold. Any oil there ?
2007 WRX
Old 05-07-2008, 12:06 PM   #3 (permalink)
rubenc66's Avatar
Car: 04 WRX
alright cool i'll do that
Old 05-07-2008, 02:40 PM   #4 (permalink)
Reputation: nagyhead is a WRX expert worth listening to nagyhead is a WRX expert worth listening to nagyhead is a WRX expert worth listening to nagyhead is a WRX expert worth listening to
are you gettting any smoke on start up, or at WOT? if so what color is it?
Old 05-07-2008, 04:55 PM   #5 (permalink)
Reputation: dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to
Smelling oil does not = running rich.
Running a catless exhaust doesnot = running rich.
Smelling oil = oil burning off from somewhere (leak) or if it's coming from the exhaust possible ring problems or excessive blowby being burned off.
Aarg matey!
ECU Pirated by RomRaider
Online
Old 05-07-2008, 06:29 PM   #6 (permalink)
rubenc66's Avatar
Car: 04 WRX
well i guess i didn't exactly mean i'm running rich just because i had catless exhaust....but i have been smelling oil when i get out of my car recently and sometimes when i sit at a light and i take off quick there's smoke that comes out but thats the only time.
Old 05-08-2008, 08:33 AM   #7 (permalink)
You do understand that "running rich" has to do with unburnt fuel and nothing to do with oil right?
rich = black gasoline smelling smoke from exhaust
oil = greyish/blue oil smelling smoke from exhaust
antifreeze = white,sweet smoke smelling from exhaust
Aarg matey!
Online
Old 05-08-2008, 11:33 AM   #8 (permalink)
rubenc66's Avatar
Car: 04 WRX
Smile
alright dude so you're just contradicting what you're saying...... of course i'll be running rich all the time then since i'm running catless because with a catalytic converter if i'm correct, it burns up all the unused gasoline? Thats the definition of a catalyst right....speeds up a reaction without consuming itself.... but anyways i was just trying to figure out what was wrong if using the phrase running rich was wrong my bad maybe i should of said burning oil or something... but yeah i thought this place was to trouble shoot problems or ask questions and i think i had a legitimate question.
Old 05-08-2008, 11:49 AM   #9 (permalink)
"running rich" has to do with how your ENGINE is running. Catalytic converters do not directly effect how your engine is running.
Engineers can't spell, sorry!
Old 05-08-2008, 11:58 AM   #10 (permalink)
Really?So your saying because you removed your catalytic covertor your ECU has now changed the amount of fuel it injects into the engine?No.Your car is still targeting and hitting the same AFR (air fuel ratio) regardless of the removal of the catalytic convertor.True,removal of the cat will allow more unburnt hydrocarbons to escape as combustion is never 100% complete."Running rich" is a state of tune,not emmisions.When something physically changes your AFR's then you are either "rich" or "lean".You do have a legitamite question,it's just your terminology is alittle off.Saying your "running rich because you smell oil" is like saying "I think I'm overboosting because my oil pressure is high".If you smell oil then either you have an external oil leak (which sould be easy to find) or an internal one (piston rings,ecessive blowby).So start with the easy one.Jack up the car and start with looking around the heads and oil pan.An external leak should be pretty easy to spot and is probably dripping onto your exhaust manifolds and burning(if thats the case).
Aarg matey!
Online
Old 05-08-2008, 07:30 PM   #11 (permalink)
rubenc66's Avatar
Car: 04 WRX
alright cool man that was easy enough thanks
Old 05-09-2008, 06:05 AM   #12 (permalink)
Isn't that the same $hit I said earlier? Did you find anything ?
2007 WRX
Old 06-01-2008, 07:59 PM   #13 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi isn't as helpful as most
Are you positive it's an oil smell? I know after I went completely catless, I had an unburnt fuel smell, along with the backfire/afterfire and occasional smoke.
