there is no reason to put a purge in a cryo system. the whole idea for a purge is to get the air out of the lines so that when you hit it (on a car with a NOS shot) you get instant response. If you want to put a purge on to make it look like you have nitrous, then that's just ###. I'm sorry, but it is.
don't worry about putting a "bomb" in your trunk. NOS is ONLY flammable when mixed with fuel. It will not burn by itself. The brackets are made very tough so as not to break during an impact, and the bottles are made to hold the pressure. These are used on race cars don't forget. just make sure you have an "over pressure release valve" installed on the bottle in case it gets too hot in your trunk. the valve will bleed off excess pressure.
'06 WRX STi
