restrictor pill - Subaru WRX Forum
post #1 of 5 Old 02-10-2008, 06:08 PM Thread Starter
restrictor pill
i have an 02 wrx with a tbe, intake, and mbc, when i bought the car it would only boost to .05 bar so i messed around with it some, and thought my boost controller was fried so i bought a mbc, now ive come to realise there was never a restrictor pill in the vacume line so figure now that is most likley the reason why it never had the correct boost. so does anyone kno where i can find a restrictor pill? can i just use any old brass bead?
thanks
jmoney2648
View Public Profile
Send a private message to jmoney2648
Send email to jmoney2648
Find More Posts by jmoney2648
Add jmoney2648 to Your Buddy List
jmoney2648 is offline
post #2 of 5 Old 02-10-2008, 06:43 PM
SWFL Scooby's Avatar
You cannot use any brass bead. The hole that is machined in the restrictor pill is to precision and works with the wastegate duty cycles and the ECU. A slight change in the size of the hole will cause drastic boost changes.
The best place to get one is the dealership.
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 5 Old 02-10-2008, 06:45 PM
the dealer should have the pill for like $10.00 and lines
gray is offline
post #4 of 5 Old 02-10-2008, 10:57 PM
Sorry didnt find the part numbr like I thought I had, but these are the sizes of restrictor pills used for the WRX/STI through the model years. Hope it helps some.
2007 STi WGDC Tables
Stock restrictor pill size = ~.0335”
Factory wastegate pre-tensioned to ~9psi
2004-2006 STi WGDC Tables
Stock restrictor pill size = ~.043”
Factory wastegate pre-tensioned to ~10psi
2005-2006 LGT WGDC Tables
Stock restrictor pill size = ~.049”
2004-2005 FXT WGDC Tables
Stock restrictor pill size = ~.047”
Factory wastegate pre-tensioned to ~7psi
2004-2005 WRX WGDC Tables
Factory wastegate pre-tensioned to ~6psi
2002-2003 WRX WGDC Tables
post #5 of 5 Old 02-11-2008, 07:16 AM
Longshot's Avatar
Just get a 3port BCS with a tune and forget the new pill, and also get rid of your MBC in the process.
DTRacing Tuned
Longshot is offline
