rattling from my engine at 3-4k rpms - Subaru WRX Forum
post #1 of 14 Old 03-28-2009, 07:57 PM Thread Starter
boost_556's Avatar
boost_556 is an unknown
here we go again guys,
now i have had a rattling coming from my engine for a while but i wanna fix that prob before it escalate to something more serious.Somewhere between 3-4k rpms is this my connecting rod bearings? and can i just replace my bearings if that's the case and maybe through some forge pistons in at the same time?don't want to hurt my pocket too much right now .Do you guys have any alternative to this, appreciate any suggestions thanks.
boost_556 is offline
post #2 of 14 Old 03-28-2009, 08:27 PM
Black05WRX's Avatar
Black05WRX is an unknown
Is it a rattle or a screeching sound? Do you have a aftermarket bpv?
Black05WRX is offline
post #3 of 14 Old 03-28-2009, 09:25 PM Thread Starter
boost_556's Avatar
yeah turbo xs bpv, but is a rattling sound like coming from the engine.
you can hear it sometimes when i start the car.
post #4 of 14 Old 03-28-2009, 09:26 PM
Eric2002wrx's Avatar
Eric2002wrx is an unknown
Heat sheild
Eric2002wrx is offline
post #5 of 14 Old 03-28-2009, 10:57 PM
VD5505's Avatar
have your hood opened while someone starts your engine and look all around, look at all the heat shields on the manifolds, and check for any loose bolts with washers on them and the bolt might of backed out somewhere.
VD5505 is offline
post #6 of 14 Old 03-29-2009, 12:13 PM
Black05WRX's Avatar
Have you pushed in your clutch and it goes away? I almost wonder if it couldnt be a throw out bearing for the fact that it happens right away when you start your car, and also mechanical sounds often times bounce around so you dont always know exactly where its comming from.
post #7 of 14 Old 03-29-2009, 12:25 PM
VD5505's Avatar
+1 to the throw out bearing thats a good idea, try that and see if it goes away, also do you have stock or aftermarket exhaust
VD5505 is offline
post #8 of 14 Old 03-29-2009, 01:33 PM Thread Starter
boost_556's Avatar
i am sure its not the throw out bearing because when u come off the clutch and climb the revs slowly up you can hear it and sometimes u don't even hear a thing when u start it up.I was told by my mechanic is the connecting rod bearing but i wanna know for sure.don't wanna pull apart my block for nothing especially in these hard times....recession
post #9 of 14 Old 03-29-2009, 01:40 PM
VD5505's Avatar
do you have any way to data log your car?? i wonder if you are pinging... what mods do you have done to your car??
VD5505 is offline
post #10 of 14 Old 03-29-2009, 06:38 PM
WRXforME's Avatar
WRXforME is an unknown
Videos help when it comes to "my car is make this noise" complaints...
WRXforME is offline
post #11 of 14 Old 03-30-2009, 12:14 PM
Strider327's Avatar
Strider327 is an unknown
Some have had the heatshield and downpipe rattle which in turn was just loose. (It happens) Others might have major problems. Post videos and we can all help you diagnose the problem correctly.
Strider327 is offline
post #12 of 14 Old 03-30-2009, 10:16 PM Thread Starter
boost_556's Avatar
thanks guys i will try to post a video.
post #13 of 14 Old 06-11-2009, 01:41 AM
brouib is an unknown
Hey im new hear and I am having that same problem and my mechanic said it was my rod bearings also. Boost 556 I have the same question as you cause I dont have deep pockets. I wanna just change the bearings, rods, and pistons, not the crank.
brouib is offline
post #14 of 14 Old 06-11-2009, 04:53 AM
if it is bearings you may as well replace the crank too...the damaged bearings will f up the crank
