» Sponsor Links
»Garage Storage and Cabinets
Old 10-05-2008, 04:12 PM   #1 (permalink)
04paulieWRX's Avatar
Car: 04 WRX
Reputation: 04paulieWRX is an unknown
quick question
i was on the grimmspeed website looking at thier external wastegate up pipes, and i was wondering what spring rate i should get for the tial 38mm. Right now i am stage 2 with about 16.5 psi. should i get the .5 bar or .9bar. thanks
Old 10-05-2008, 07:45 PM   #2 (permalink)
EWG with a stock turbo is not going to make you any power. Why are you doing this mod? You're going to need a low boost actuator which if you ever upgraded would have to go anyway. Again, there's no gains to this mod. Wait till you have a much larger turbo to worry about external gating.
Engineers can't spell, sorry!
Online
Old 10-05-2008, 10:09 PM   #3 (permalink)
Black05WRX's Avatar
Car: 05 WRX
Reputation: Black05WRX is an unknown
Wait till your using something bigger then a 20g to do a wastegate setup like that.
Old 10-06-2008, 05:56 PM   #4 (permalink)
SilverSuby's Avatar
Car: 04 WRX
Reputation: SilverSuby is an unknown
You could use that setup if you were running a 20g
When I turn my car on............it returns the favor!
Old 10-06-2008, 07:39 PM   #5 (permalink)
Club Region: SoCal
Trader Rating: (1)
Reputation: WReXd is a helpful contributing member
You will get a lot more gains with a larger turbo, but I have seen people go EWG on the stocker and they were happy with the results. If you're set on doing this with the stock turbo, the .5 bar spring will be better suited for you. If you're planning to upgrade to 18g+, get the .9 bar.
