Old 05-14-2004, 04:08 PM   #1 (permalink)
Reputation: SiDsWRX is an unknown
Send a message via AIM to SiDsWRX
Question Problems with idle
I have an 04wrx with a Type-S Blow off (full atmospheric) and a N1 catback. Whenever i drive my car and shift from any gear to neutral (of couse while slowing down) i noticed my tach would drop all the way down to 0rpms then bounce back up to 1000 and drop to 500(standard rpm). I dont know if this is healthy for my car or what? I need help, please, if someone has any suggestions. Thanks
Old 05-14-2004, 04:12 PM   #2 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
0 RPMs means the engine wouldn't be running. No its not good for the car either. Not sure of what the problem is though sorry.
Old 05-14-2004, 04:23 PM   #3 (permalink)
Cosmo's Avatar
Sounds like the BOV might not be closing all the way. But, if it's not stalling, it's not a huge problem.
Old 05-14-2004, 05:20 PM   #4 (permalink)
Tut4u2's Avatar
Reputation: Tut4u2 is an unknown
This is bad! It's doing that because the spring isn't closing fast enough. The samething happens when you vent the stock BOV. Tighten the screw on the top of the BOV and that should do the trick.
And basically what happens is that the ECU dumps for fuel in there so the engine keeps on turning.
The other solution is to recirculate it.
Che
Old 05-14-2004, 06:03 PM   #5 (permalink)
Car: 04 WRX
Trader Rating: (1)
I had a feeling it had something do w/ the BOV but I didn't know exactly what.
Old 05-14-2004, 11:15 PM   #6 (permalink)
Talking Thanks Guys
Thanks for all the help guys! i really appreciate it!
