Power Stage 2-what should I expect? - Page 2 - Subaru WRX Forum
post #16 of 19 Old 09-28-2005, 07:42 PM
Quack's Avatar
Quack is more helpful than not
here's the cliff notes to what he posted above:
"Mustang's place a load on the vehicle and use a load cell to measure the actual torque being put down to the rollers. From torque and RPM, we get HP. Dynojet measures the "inertia weight" of the rollers and then measure the acceleration rate of the rollers using a speed sensor. Based on those 2 numbers, F=ma. From Force, we get HP. From HP and RPM, we get torque. Completely back-asswords way of doing it because torque is a real, measured number and HP is a calculated number."
Quack is offline
post #17 of 19 Old 09-28-2005, 08:51 PM
suddenthomas's Avatar
suddenthomas is more helpful than not
My engine is still pretty fresh it only has 25,000 miles very strong still and cant wait once i get the runs done i guess i will just post for everyone else in my boat thanks guys and ill keep in touch
suddenthomas is offline
post #18 of 19 Old 09-29-2005, 02:24 AM
bigbadbuddha's Avatar
Images: 15
dyno
Where i'm from there are 3 tuners wthin 300 miles. All fo them use the Mustang. In Ottawa Canada my city my sponsors KVR run the mustang. I pulled a a whopping 237 Hp and 224 ft/lbs of torque consistently.
I had my car tuned by 4 star Motor sport in Toronto(again Canada), and they got the same numbers.
MODS: HKS up pipe & Down pipe, Turbosmart dual stage BOV, AEm short ram Intake, NGK Iridium plugs 1 step colder, 580 cc injectors Walboro fuel pump, Turbosmart electronic boost controller(E-Boost2). and tuned with CObb access port.
Now I don't use those numbers, I use my base map numbers and check the difference...
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #19 of 19 Old 09-30-2005, 09:32 PM
Back on the subject and that was how much power to expect from a stage 2 setting. I found out from a good source to run around 300-310 hp at the tranny I ll be happy with that for about a month or two like the rest of us.
