Perrin Crank pulley - Page 2 - Subaru WRX Forum
post #16 of 20 Old 03-23-2011, 12:12 AM
Exactly my point. Sure, no one's reported problems or have experienced them. But it's an obvious risk like any mod we do. The question you need to ask yourself is if that little gain with the given the little risk worth the hundred or so dollars you spend on this mod.
Personally, I'd put it toward a part I KNOW will gain me performance I'll see or feel.
post #17 of 20 Old 03-23-2011, 10:23 AM
So we know that the stock crank pulley was well-engineered for a specific purpose: to absorb any extra vibrations that might escape from a naturally balanced engine, which is certainly a good thing. A small benefit can be had there.
We also know that the stock crank pulley weighs several pounds more than a lightweight aftermarket pulley, so the reduction in rotating mass by switching to an aftermarket pulley is a small benefit too. At the same time, the lightweight crank pulley does not have the ability to absorb vibrations like the stock crank pulley does, so that's a bit of a hinderance.
You're spending money for something that both helps and hurts your car, so in the end, it really does nothing.
But... with the amount of movement in every direction that entire car experiences while in motion under normal driving circimstances, is the ability of the stock crank pulley to absorb small vibrations from the naturally balanced engine completely necessary? Are the tight tolerances of the bearings and other parts inside the engine enough to keep the crank spinning true without the aid of the dual rotating masses of the stock crank pulley? Was the stock crank pulley over-engineered? Is the addition of the lightweight crank pulley MORE of a benefit than a risk!? :eek:
post #18 of 20 Old 03-23-2011, 07:51 PM
I'm seriously at a loss as to what the big deal about doing it is? Its a bling mod IMHO, It doesn't do much but make you feel good that you "changed" your rev ups. If you do clutch work and get light weight flywheels or drive shafts. That'll be where you really see rev ups being really different. I don't know, to each his own. But, it seems like a worthless mod to me.
post #19 of 20 Old 03-23-2011, 11:37 PM
WRX04RPM is an unknown
There can be no gain of "horsepower" from adding a light weight crank pulley. By adding less rotational mass you can see a small increase torque however. i wouldnt expect alot though
WRX04RPM is offline
post #20 of 20 Old 03-24-2011, 07:00 AM
It's rotational weight....Any little bit helps <--My ¢2
