Perrin Crank pulley - Subaru WRX Forum
post #1 of 20 Old 03-12-2011, 07:16 AM Thread Starter
AllExtinct's Avatar
Question Perrin Crank pulley
Was looking into getting the Perrin crank pulley but wanted to see reviews on it first.
I know weight reduction is good but does the crank pulley give you a noticeable improvement?
It says it does but then again companies can sell bacon to a pig also.
AllExtinct is offline
post #2 of 20 Old 03-12-2011, 03:11 PM
No. I did not notice a damn thing after installing mine.
post #3 of 20 Old 03-12-2011, 09:12 PM
c2bcoolwrx's Avatar
Quicker revs, but nothing mind blowing.
c2bcoolwrx is offline
post #4 of 20 Old 03-12-2011, 09:13 PM
Ditto.
The main benefit I get from it is the satisfaction of knowing I installed it myself and I'm happy to include it as another part in my mod list (mostly because it sounds impressive to people who don't know the truth about it). I saw a before/after video with a tachometer view and the needle after the aftermarket lightweight crank pulley was installed revved slightly faster than the one before the install. That leads me to believe it does benefit the car in some way - maybe it actually does free up a hp or more, who knows.
More pulley info here: Pulley FAQ: Read if you are thinking of buying one! - NASIOC
Honestly, don't think too hard about this one. If you have 100 bucks (+/-) to blow and it will make you happy, then go for it
I've had my Perrin lightweight crank pulley on my car for almost 70,000 miles now and I'm still happy I bought/installed it.
post #5 of 20 Old 03-13-2011, 07:53 AM Thread Starter
AllExtinct's Avatar
They make it sound so impressive that its way lighter than the OEM pulley and gives you quicker TR.
I guess so far the one they got right was the install?
I think I'll wait this engine dresser out till I have the money.
Thanks for the input guys.
post #6 of 20 Old 03-13-2011, 10:15 AM
wagonracer's Avatar
I wouldn't toss it out as an engine dresser. I've had mine on my WRX for so long that I forget if I noticed a difference when installed, but there is no doubt that loosing rotating mass will give you small horsepower gains. A year or so ago I put one on a '95 Impreza 1.8 and the difference in performance and MPG was quite noticeable.
wagonracer is offline
post #7 of 20 Old 03-13-2011, 10:00 PM
I wouldn't waste your money. I can see quicker revs but I can't see horsepower gains. In any case, it's not noticeable. The problem with this crank pulley is that it is a solid machined piece. The factory one is two pieces with rubber sandwiched in the middle which acts as a harmonic dampener. I have an old SAE article somewhere on a Subaru engine that basically stated it's important to have that dampener at higher RPMs to reduce unwanted vibration. So it's not a risk free mod either.
post #8 of 20 Old 03-15-2011, 07:21 AM
There are two sides to the harmonic damper issue. Taken from Unabomber's Manifesto, Pulley FAQ:
"Isn't replacing the stock harmonic damper (pulley) bad? Subarus do not come with a harmonic damper or balancer like some other vehicles do. For other manufacturers' vehicles, this is a legitimate concern. Proof:
'Thank you for your patience as I checked with our Technical Services Department regarding your message below. They advised that the crank pulley is a pulley and nothing else. It is not used as a harmonic damper/balancer.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again.'
Best wishes,
John J. Mergen
Customer Service Department
Subaru of America, Inc."
I think you're right about the high rpms thing though - sometimes the lightweight crank pulleys create a "false redline."
Bottom line: install it at your own risk. If there are any negative issues, revert back to stock. Most people don't experience any serious negative issues; most are slightly positive.
post #9 of 20 Old 03-15-2011, 09:19 AM
c2bcoolwrx's Avatar
Perrin Pulley is fine. It is the underdrive pulley's that cause the problems. There Perrin is the same size as stock, just made with lighter materials. Thus, less rotating mass and more efficient revs.
post #10 of 20 Old 03-21-2011, 09:08 PM
Best wishes,
John J. Mergen
I've seen that letter. And I saw your point back then. I agree we do not have a harmonic balancer. But reading about the purpose of the way the factory pulley was designed in an SAE document, regardless that it was an older legacy engine, the pulley I pulled off was pretty much the same concept. Otherwise, there is absolutely no reason to design the pulley in two pieces with a rubber medium in the center. It would have been cheaper and more cost effective to make it out of once machined piece.
I have the document on a HD at work. I'll see if I can dig it up and post the important pieces.
post #11 of 20 Old 03-22-2011, 09:36 AM
Well, Subaru calls it a balancer...
The cover of the document.
The excerpt about the pulley I pulled out.
post #12 of 20 Old 03-22-2011, 03:40 PM
Interesting. Thanks for posting
post #13 of 20 Old 03-22-2011, 03:44 PM Thread Starter
AllExtinct's Avatar
Guess it doesn't make that much of a difference if you keep the OEM pulley or aftermarket since noone has stated anything about abnormal vibration after installing a aftermarket pulley.
Though the aftermarket does state to be lighter but I guess there's pro's and con's to anything you put on that is aftermarket.
post #14 of 20 Old 03-22-2011, 03:46 PM
I'm keeping the oem pulley on in my build.... I'll loose enough rotating mass with the carbon clutch and lightweight flywheel. Add in the drive shaft and a crank pulley isn't going to be noticeable. It's such a small diameter it doesn't do much anyways in reducing its weight.
post #15 of 20 Old 03-22-2011, 04:44 PM
I've kept my OEM pulley but like Chris I've lost alot of weight with the lightened flywheel and clutch, in addition my light weight driveshaft but I will say those mods did really increase throttle response and the motor revs way freer, I'm not sure how a pulley would perform but for the price it may not be bad just to give it a whirl and if you don't like it I'm sure you could sell it on the forums almost for cost
