PE 1818 Vs. 16G - Subaru WRX Forum
post #1 of 8 Old 12-05-2005, 04:25 PM Thread Starter
knot04 is an unknown
Send a message via AIM to knot04
PE 1818 Vs. 16G
what is the main difference between these two other than price? they seem to be a close match, both a step up from the VF34 in terms of power, and seem like they would come on boost at close to the same time. any thoughts?
also, does the 1818 share the VF34 compressor, and the 1820 the VF22 compressor. i understand this to be the case, with the only differences being the size of the turbin and compressor wheels along with a different center cartrige. am i correct?
knot04 is offline
post #2 of 8 Old 12-06-2005, 12:55 PM
Lost One's Avatar
Lost One is an unknown
Pasted from another thread, but looks like a 16g will flow more.
Turbo Type ----------- Approx flow @ pressure
Stock Turbo ---------- 360 CFM at 14.7 PSI
IHI VF 25 ------------- 370 CFM at 14.7 PSI
IHI VF 26 ------------- 390 CFM at 14.7 PSI
T3 60 trim ------------ 400 CFM at 14.7 PSI
IHI VF 27 ------------- 400 CFM at 14.7 PSI
IHI VF 24/28/29 ------ 410 CFM at 14.7 PSI
IHI VF-30/34 --------- 435 CFM at 14.7 PSI
SR 30 ----------------- 435 CFM at 14.7 PSI
IHI VF-22 ------------- 440 CFM at 14.7 PSI
T04E 40 trim --------- 460 CFM at 14.7 PSI
PE1818 --------------- 490 CFM at 14.7 PSI
Small 16G ------------ 505 CFM at 14.7 PSI
ION Spec (stg 0) ---- 525 CFM at 14.7 PSI
Large 16G ----------- 550 CFM at 14.7 PSI
SR 40 ----------------- 595 CFM at 14.7 PSI
18G ------------------- 600 CFM at 14.7 PSI
PE 1820 -------------- 630 CFM at 14.7 PSI
20G ------------------ 650 CFM at 14.7 PSI
SR 50 ---------------- 710 CFM at 14.7 PSI
GT-30 ---------------- 725 CFM at 14.7 PSI
60-1 ----------------- 725 CFM at 14.7 PSI
GT-35R -------------- 820 CFM at 14.7 PSI
T72 ------------------ 920 CFM at 14.7 PSI
Lost One is offline
post #3 of 8 Old 12-06-2005, 01:11 PM Thread Starter
yea, ive seen that table, but thanks for posting it again. the main issues that ive heard regaurding the 1818 is that its laggy. however due to the ammount of air it flows, it shouldnt be as laggy as a 16G. right?
knot04 is offline
post #4 of 8 Old 12-06-2005, 02:13 PM
Lost One's Avatar
Well, that's not just based on air flow alone. Inlet/outlet size, wheel size and weight, etc etc all effect spool time. I wish I had some better info for ya, but I don't have any experience with either of those turbos.
Lost One is offline
post #5 of 8 Old 12-06-2005, 06:50 PM
blackoutX is an unknown
Send a message via AIM to blackoutX
love the table helps alot , now only if it could be it hp
blackoutX is offline
post #6 of 8 Old 12-06-2005, 06:54 PM Thread Starter
AWHP or TQ would be next to impossiable given the WIDE veriety of supporting mods (exhaust, EM, intake, intercooler ect.)
knot04 is offline
post #7 of 8 Old 12-06-2005, 07:08 PM
i mean on average
post #8 of 8 Old 12-06-2005, 08:35 PM
DUBXTCY's Avatar
Images: 18
DUBXTCY is an unknown
Send a message via AIM to DUBXTCY
table ideas...
what about percentage of hp increase from stock?
is this approx possible?
-KJ
Cobb Stage II 2006 WRX
DUBXTCY is offline
