Oil catch cans: 1,2 or 3 and why? - Subaru WRX Forum
post #1 of 7 Old 05-18-2010, 11:40 AM Thread Starter
fuapiti's Avatar
Here is the thing. I was offered a Cusco OCC for a fair and decent price so I bought it. While researching on how to install it properly (instructions are in Japanese) I began to run into explanations on which are the wrong ways and the right ways of installing them, then I read about installing 2 cans and then 3 cans.
The reality is that my car is a daily driver right now and although I do drive it rather aggressively sometimes I hardly ever go to the track anymore. Should I ditch the idea of installing it? should I install just one? two? three? why?
Oh my car is an 05 WRX, stage 2 and I have an STi intercooler waiting to be installed as soon as I fing an STi shroud and a silicone Y-pipe...
fuapiti is offline
post #2 of 7 Old 05-18-2010, 01:06 PM
Ditch it. You don't need it.
post #3 of 7 Old 05-18-2010, 02:04 PM Thread Starter
fuapiti's Avatar
Could you elaborate on the "why" part?
fuapiti is offline
post #4 of 7 Old 05-18-2010, 03:22 PM
you'll get blow by no matter what. i have no oil in my turbo since i look sometimes so that means no oil is getting in there via the valve covers or crank case vents. however i was getting oil in my intake manifold from the crank case vent where it splits off a T going into the PVC valve. since im blow through i capped off my intake manifold and no longer run a PVC valve. that means the oil that was going to the IM can now go to the inlet then turbo then pipe ect ect. so i put in a catch can. used clear hose so i could see if oil is getting to the inlet but so far so good. its not a bad idea. at least do the crank case vent to catch can then back to the T going to the inlet and your PVC.
post #5 of 7 Old 05-23-2010, 03:44 PM
On the 02-05 WRX/STI's the PCV is diverted from the intake manifold to the turbo inlet under boost. So those would be the two places I would put them. The crank case vent will see the least of it considering its job acts as an air return like in a HVAC system. Fresh air is pulled in from there.
dumdum is offline
post #6 of 7 Old 05-24-2010, 10:01 AM Thread Starter
fuapiti's Avatar
^Thanks for the diagram!
fuapiti is offline
post #7 of 7 Old 06-08-2010, 02:28 PM
phatmike0704's Avatar
phatmike0704 is an unknown
Send a message via AIM to phatmike0704 Send a message via Yahoo to phatmike0704
i installed mine wrong but whatever, i just keep it in there for decoration. only 18 bucks on ebay and i made my own filter from foam. A subaru technician told me we have a stock one. didnt show me where though
phatmike0704 is offline
