Next step-up from TD04? - Page 2 - Subaru WRX Forum
post #16 of 32 Old 08-26-2011, 06:29 AM
06-07 WRX injector flow = STi injector flow
post #17 of 32 Old 08-26-2011, 04:20 PM
bfodle is an unknown
bfodle is offline
post #18 of 32 Old 08-26-2011, 04:21 PM
These are supposed to be good with VF turbos and 16G turbos. At least from what I've been reading for the last few months, paired with a Walbro 255 fuel pump.
bfodle is offline
post #19 of 32 Old 08-26-2011, 04:49 PM
Those won't work with your manifold. Those are side feed injectors you need top feed injectors.
post #20 of 32 Old 08-26-2011, 06:11 PM
02-07 WRX & 04-07 STI Deatschwerks Top & Side-Feed Injectors: JSC Speed
Top Fed:
WRXs 2002-2007
STI 2007
Side Fed:
STI 2004-2006
2006 WRX and up use 565cc injectors and 2004-2006 STIs used 550cc injectors.
post #21 of 32 Old 08-27-2011, 07:51 AM Thread Starter
AllExtinct's Avatar
So to narrow it down new turbo upgrade = new injectors, new fuel pump, custom tune to get the full effect.
Is there any need to step the plugs colder also?
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #22 of 32 Old 08-27-2011, 09:43 AM
I would say yes on the NSC plugs.
I didn't realize the older STi injectors were 550cc... Nice to know Kirt.
post #23 of 32 Old 08-27-2011, 10:09 AM
I was under the impression that with the fuel rails from these side feed injectors that I could swap them. Is that not correct?
bfodle is offline
post #24 of 32 Old 08-27-2011, 04:38 PM
No that would be a waste of plugs. I don't and look at my mods...People will debate it, but personally it's not needed. Indexing the plugs would be more of a benefit than colder plugs.
Not that I am aware of.
Last edited by psinuse; 08-27-2011 at 09:00 PM. Reason: God my spelling is awful...
post #25 of 32 Old 08-27-2011, 07:16 PM
Yep, it held my lil VF39 back some...until my tuner tuned them for 105% duty cycles. lol. Way back when...my car was almost stock. It seems like such a long time ago.
Unless you are beating on your car more than you are driving it the speed limit....I don't think next step colder plugs do anything.
Are you using the fuel rails from a 2006 STI and the injectors?
post #26 of 32 Old 08-27-2011, 07:56 PM
Was thinking about stepping up from TD04 but nothing major that would make me buy a bunch of other parts. One that would be work with AP.
If you upgrade your turbo you will have to buy a lot of other parts to keep up with it. Injectors, intercooler, and fuel pump at a minimum to take advantage of your bigger turbo. My old WRX hauled ass with a VF30, Pinks and an intercooler. The OTS maps suck for these kinds of upgrades. You really need to get a custom tune to take advantage of the upgrades.
Kjott21 is offline
post #27 of 32 Old 08-27-2011, 08:28 PM
I run the stock plugs on my setup also, so you can do it and be fine. Like Keith said, just check the gaps before dropping them in. And upgrading a turbo, and supporting mods, the Cobb AP can still be used. I have a dozen custom maps for my 20G setup, you just need a protune, which is better for the car and any setup to include stock.
post #28 of 32 Old 08-27-2011, 10:59 PM
Well, I'm not using them, but I have the rails and injectors from an 06 STi.
bfodle is offline
post #29 of 32 Old 08-28-2011, 11:18 AM
In order to swap to the side feed injectors you would need change out the TGV housings, fuel rails, and injectors. More work than it is really worth. Sell the STI injectors and get a set of Deatchwerks injectors.
DeatschWerks.com | WRX 2002-11 | WRX | Subaru | Sport Compact | Fuel Injectors | DeatschWerks
Kjott21 is offline
post #30 of 32 Old 08-28-2011, 11:33 AM
Thanks for the info. Sounds like too much for what it's worth. I'll just go with the top feeds and sell the side feeds.
bfodle is offline
