newly installed accessport - Subaru WRX Forum
post #1 of 3 Old 08-21-2005, 10:03 PM Thread Starter
ajc_wrx is an unknown
I just installed my accessport on a 2002 wrx. Works fine, maps are switched ok and it sync's with the computer. Problem, my engine check light turned on and will not shut off anymore.
ajc_wrx is offline
post #2 of 3 Old 08-21-2005, 10:33 PM
WRXforME's Avatar
WRXforME is an unknown
I cant really help you because I have no experience with it. I just wanted to know how your car is performing with it now.
WRXforME is offline
post #3 of 3 Old 08-22-2005, 05:32 AM
Turbocanon is an unknown
The main menu on the AP will give you the option to read the code. Do that,
and once you know what the problem is, you can clear it by choosing "re-set
ECU" option.
When you install the unit, it automatically clears and locks out the O2 sensors
and EGR, etc, so if you have a code, you need to find out what it is.
Mine ran lean after I installed my AP, and I had to ditch my Injen CAI, which
BTW, ran ok before the AP install.
Hope this helps!
Bob
Turbocanon is offline
