-   -   new turbo with less than stock boost (http://www.wrxtuners.com/forums/f52/new-turbo-less-than-stock-boost-26527/)
scoobyrooftw 06-27-2009 03:07 PM
i just swapped out my turbo for another stock one and now im only hitting 13 psi. does it just need broke in? or is something wrong?
i also put a turboxs uppipe on and already have a TBE.
boost_556 06-27-2009 05:46 PM
doesn't the stock turbo boost around 13.5 psi? do you have a boost controller? perform a boost leak test as well.
newtothegame 06-27-2009 07:28 PM
The stock one you got, is it used? Have you checked the wastegate also?
scoobyrooftw 06-27-2009 08:00 PM
the stock one i got is used. the guy i got it from said he ported the inlet and the wastegate
also i check the connection on my bov and it was leaking. i fixed that and now it spools to 16 psi drops to 12 or so and then goes to 14 and stays there
how do i do a boost leak test?
boost_556 06-27-2009 09:49 PM
its pretty simple if u have the right tools, if you google boost leak wrx will see one forum where they have a good example of doing a boost leak.its basically pressurizing the system from the turbo inlet hose with roughly about 30 psi then listen carefully for any leaks if there is you will definitely hear it.
