» Sponsor Links
»Garage Storage and Cabinets
Old 10-25-2003, 09:36 PM   #1 (permalink)
Reputation: EA704LIFE is an unknown
New turbo...
Guys,
I recently got a new turbo (IHI VF 30) and I'm worried the engine can't handle it without an ECU mapping of some kind. I've got the following:
Intake
Turbo back exhaust
Up Pipe
Blitz Boost Controlloer
Power meter
BOV
Are the injectors going to be able to handle the bigger turbo? What kind of PSI am I able to run?
Thanks for your help,
Chris
Old 10-25-2003, 09:58 PM   #2 (permalink)
Tut4u2's Avatar
Reputation: Tut4u2 is an unknown
You do need injectors and a computer management system of somekind. With out those two you risk screwing up something in your car.
Che
Old 10-25-2003, 09:59 PM   #3 (permalink)
Reputation: EJ20 is an unknown
Just fun a low psi, I'd say at or below stock(preferabley below). Totaly up to you. Go to www.nasioc.com see what they think.
Old 10-25-2003, 10:00 PM   #4 (permalink)
SloRice's Avatar
Reputation: SloRice is an unknown
Send a message via AIM to SloRice
You are definately gonna need some sort of engine management, injectors and fuel pump. I have a Stage 2.5 setup and I'm running 90-95% injector duty cycles. So with a bigger turbo, you are gonna max out the injectors....which equals leaning the motor out real bad. Another thing to look at since you are running a bigger turbo is a new top mount intercooler.
Tim
Old 10-25-2003, 10:00 PM   #5 (permalink)
Like he said though very risky.
Old 10-26-2003, 12:11 AM   #6 (permalink)
Reputation: kylo19 is an unknown
Send a message via AIM to kylo19
I would have to disagree. Its only a slightly bigger turbo. I know a lot of people in my area have upgraded turbos without fuel. I have had my vf 23 for 1000 miles and had nothin, but just to be completely safe i am planning on getting fuel soon. My advice to you would be not to run too high boost.
Old 10-26-2003, 03:31 AM   #7 (permalink)
What's a safe boost level? I was planning on going the Ecuteck route later this spring because of the waether here but is it safe to put the turbo in, run it at a low boost level and remap once the weather turns more favourable?
Thanks
Chris
Old 10-26-2003, 08:45 AM   #8 (permalink)
Cosmo's Avatar
A VF23 and a VF30 are not the same. The VF30 is substantially bigger. Also, you will not be safe running anything other than the stock turbo on the stock fuel system and engine management. I know, everyone knows somebody's brother's cousin's friend who runs a huge turbo on the stock injectors and runs 10 second 1/4 mile times.
So, I guess it comes down to what you want to do. If you want to run your car with a very high chance of damaging or destroying the engine, go ahead and put the turbo on. After all, I'm sure there are plenty of companies that would be happy to sell you a new engine.
Or, you can do it the safe way... the RIGHT way... and wait until you have upgraded your fuel system. Everyone wants to tell you that if you run the factory boost level you will be fine. They are wrong. Your new turbo might be putting out the same amount of PRESSURE as your stock turbo, but it's producing a lot more AIRFLOW.
And, I would also advise against getting an Ecutek. The UTEC is a much better option.
Old 10-26-2003, 01:18 PM   #9 (permalink)
thanks for all the info. Just curious, why the Utec over Ecuteck?
Chris
Old 10-26-2003, 01:20 PM   #10 (permalink)
TheRex's Avatar
Reputation: TheRex is an unknown
Send a message via AIM to TheRex
the stock injectors go static at 16psi without management i believe
Old 10-26-2003, 04:07 PM   #11 (permalink)
Tut4u2's Avatar
UTEC is more fun .
Che
Old 10-26-2003, 04:34 PM   #12 (permalink)
the only problem is here in Vancouver I need to go through an emmsions test every year. Does Utec allow to flip back to stock mode when I need to run pass the government?
Thanks
Chris
Old 10-26-2003, 07:21 PM   #13 (permalink)
Cosmo's Avatar
Yes. Position "0" on the UTEC map selector switch is stock.
Old 10-26-2003, 07:26 PM   #14 (permalink)
That makes that much easier. Thanks for all the input. Will the stock injectors be able to hanle it? Same goes for fuel pump?
Thanks
Chris
Old 10-28-2003, 07:41 AM   #15 (permalink)
WRXblurr's Avatar
Car: 05 Evo MR
Reputation: WRXblurr is an unknown
nope.. you will need sti injectors and a up graded fuel pump.. stock injectors max out very quickly .
