» Sponsor Links
»Garage Storage and Cabinets
Old 02-28-2004, 11:45 PM   #1 (permalink)
Reputation: Maulzar is an unknown
Send a message via AIM to Maulzar
New MBC, remove factory boost controller?
I just got the turbo XS dual stage boost controller and the instructions said that if your car already has a factory boost controller you will need to remove it. Does a 2002 WRX have a factory boost controller that I need to remove, this confuses me? If there is one where is it and how do i remove it?
Old 02-29-2004, 10:48 AM   #2 (permalink)
Tut4u2's Avatar
Reputation: Tut4u2 is an unknown
No there isnt one. Just put it in between the wastegate line and it should be fine.
Che
Old 02-29-2004, 11:36 AM   #3 (permalink)
Cosmo's Avatar
Your car has a factory boost controller. But, you don't need to remove it. Just install the new MBC and you'll be fine.
Old 02-29-2004, 04:29 PM   #4 (permalink)
Tut4u2's Avatar
I meant there isnt one in the sense that you can change the boost, hence there is no factory boost control, its just a selnoid.
Che
Old 03-01-2004, 08:41 PM   #5 (permalink)
zoinks's Avatar
Reputation: zoinks is an unknown
Send a message via AIM to zoinks
I would suggest that if you are going to use an MBC, get a pressure solenoid (dawes or grainger) so that you can switch between stock boost to whatever you preset the MBC to with a flip of a switch. That way you won't get PTFB that can cause high EGT's.
