New Exhaust help? 02 - Subaru WRX Forum
post #1 of 8 Old 05-24-2012, 08:56 PM Thread Starter
Alright first off thanks for your help to any and all of you who take the time to respond to this question i recently received my new exhaust system after about a month 0.o . and i was talking to my buddy and he says that doing the exhaust on a turbo is way different then on a non-turbo engine i bought a full system and i have read that i should expect some rusted bolts and i should have some PB ready. i have changed the exhaust on some non-turbo cars when i was running with some of my buddies who loved american muscle(namely Mustangs(i still run with them i just got into rally too) and it wasn't too bad
but my real question is (if you don't care enough to read that paragraph up there)
Is it any harder putting a whole exhaust system on a turbo charged WRX than on a non-turbo Mustang?
roran is offline
post #2 of 8 Old 05-24-2012, 08:59 PM
Nope.
post #3 of 8 Old 05-24-2012, 09:08 PM
bad grocerygetter's Avatar
Define whole exhaust. Turbo back or full exhaust, including header,and uppipe. If the uppipe is included get ready for some time under your car. Not a fun install. Now a catback or even a turbo back is pretty easy.
Kevin.
bad grocerygetter is offline
post #4 of 8 Old 05-25-2012, 03:06 AM
I have to agree with both gentlemen depending on what you call a full exhaust.
post #5 of 8 Old 05-25-2012, 05:23 AM
yelljack's Avatar
It isn't too difficult, growing up I learn a little bit on late 70s and early 80s American muscle. I have over the years replaced uppipe, down pipe and catback on three different subies (02 and 03 WRXs and a 05 STi), my car is on it's 3rd downpipe and catback, including stock.
There is less room to work with on a WRX than say an 84 Mustang, but there are tricks you learn along the way, pick the brains of the folks on this site and checkout scoobiemods.com
If you are going to be working on the exhaust of a turbo buy 6 point combo wrenches, and letting PB soak into the bolts for an hour helps. Once it is ready to be put back together use anti-seize, just in case. What I just told you, you probably already know...but those were things I didn't know and wished I had before my first time working on a WRX
Eric
yelljack is offline
post #6 of 8 Old 05-25-2012, 07:41 PM
atech34's Avatar
I am actually in the same boat right now not to thread jack you or anything, but I just got the final piece to my exhaust system and by full I mean header up pipe turbo back full, now my question right now is, can I install this system even though I won't be getting tuned for a couple more weeks?
Can I install it reset the ecu and have no major drawbacks? I know that with the highflow DP added the turbo will boost faster does this effect the engine so bad that I should wait? I drive like a grandma and am old enough to be patient with playing around with the new rumble.
atech34 is offline
post #7 of 8 Old 06-04-2012, 09:08 AM
yelljack's Avatar
atech, you will get O2 CEL codes but that should be it
Eric
yelljack is offline
post #8 of 8 Old 06-04-2012, 12:10 PM
atech34's Avatar
I actually didn't have a CEL prior to getting it tuned could just be the specific setup I am using though.
atech34 is offline
