Need a little help - Subaru WRX Forum
post #1 of 12 Old 10-01-2012, 08:42 PM Thread Starter
Need a little help
Kind of new to the Subaru scene and I just recently changed turbo to Vf34/sti intake with pink injectors / dp/ up pipe/ aps cai/ one small problem I have one hose that attaches to a nipple in the intake under where the intercooler would be hooked up above that nipple is another nipple which is in the right place so I am just wondering if anyone would be able to help me out with this or point me in the right direction ...
Thank you in advance
Chris
Deacx is offline
post #2 of 12 Old 10-01-2012, 08:58 PM
AllExtinct's Avatar
Originally Posted by Deacx View Post
I have one hose that attaches to a nipple in the intake under where the intercooler would be hooked up above that nipple is another nipple which is in the right place.
If you could possibly get pics up it might help out a little.
Your explanation is somewhat confusing.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #3 of 12 Old 10-01-2012, 09:05 PM Thread Starter
here is a pic
Deacx is offline
post #4 of 12 Old 10-02-2012, 06:31 AM
You can't use an STI intake manifold on your car. The throttle body won't fit.
post #5 of 12 Old 10-02-2012, 08:08 AM Thread Starter
Are you serious ??? Lol ... Please let me know what the difference is cause car started great and sounds good ... Just noticed this little issue ...
Deacx is offline
post #6 of 12 Old 10-02-2012, 09:10 AM
A DBC throttle body is not compatible with a DBW intake manifold.
See if you can spot the difference.
post #7 of 12 Old 10-02-2012, 09:29 AM Thread Starter
Ok so car would still run if I have it All hooked up ???
Deacx is offline
post #8 of 12 Old 10-02-2012, 09:48 AM
Not sure if I wasn't clear. You cannot run your DBC throttle body on this manifold. Not sure how much you want coolant potentially getting into your engine.
post #9 of 12 Old 10-02-2012, 10:24 AM Thread Starter
Ok just took off both throttle bodies and they are identical on intake side and throttle bodies them self ... Also just to let you know that pic I posted was a pic off the net ... Just wanted to know where that nipple would go ... Thanks again starting to think maybe this is not a sti intake manifold...
Chris
Deacx is offline
post #10 of 12 Old 10-02-2012, 11:56 AM
Gotcha.
I'll get back to you later on your question if someone else doesn't answer it 1st.
post #11 of 12 Old 10-02-2012, 05:46 PM Thread Starter
Ended up figuring it out ... Thanks for all the input
Deacx is offline
post #12 of 12 Old 10-02-2012, 07:44 PM
PCV valve connects like this:
http://www.iwsti.com/forums/how-inst...pcv-valve.html
