need a CEL fix for 05 - Subaru WRX Forum
 1Likes
  • 1 Post By turmic
post #1 of 9 Old 01-21-2010, 07:42 PM Thread Starter
ej20_allday is an unknown
My 05 WRX was a stage 2 before I bought it. It has the catted d-p goin to a catless exhaust.
Now a buddy of mine told me that the CEL fix only works for 04 models. Is this true? If not, where and what CEL fix would you recommend?
ej20_allday is offline
post #2 of 9 Old 01-21-2010, 10:42 PM
fuapiti's Avatar
get an AccesPort...
fuapiti is offline
post #3 of 9 Old 01-22-2010, 08:36 AM Thread Starter
no, its pointless for me, im going to sell the car next fall
post #4 of 9 Old 01-22-2010, 12:41 PM
CEL fix works for any year car. Just search it on here and you can/will find it.
post #5 of 9 Old 01-22-2010, 12:48 PM
c2bcoolwrx's Avatar
'04 and '05 are same. If it works for an '04 it would work for an '05. (just as newtothegame said)
Are you talking about the 2.2 ohm resistor mod? If so read this:
2.2K Ohm Resistor Mod - ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
But, the resister can be purchased for CHEAP at radioshack. Otherwise, you will require a tune (you should have a proper stage 2 tune on the car anyway or its bad juju).
c2bcoolwrx is offline
post #6 of 9 Old 02-04-2010, 04:45 AM
Matwal is an unknown
depends on which cel you are getting
if its the one for the missing EGT bung in the aftermarket up-pipe, putting a 2.2kohm resistor in will take care of that cel.
if its the downpipe cel because there are no cats now, catless dp and mid pipe, there is a fix where you go buy some spark plug anti foulers from an auto part store. search for this mod for specific instructions
both of these mods will take care of either cels and no engine management(cobb, opensource) is needed
Matwal is offline
post #7 of 9 Old 02-05-2010, 09:56 PM
You'll still have messed up closed loop/open loop fuel cycles. None of the cel fixes correct that. A tune does, which also clears the CELs. Wow...imagine that.
Jovani likes this.
post #8 of 9 Old 05-30-2013, 01:16 AM
Jovani is an unknown
Thats what I'm looking for is there a guide on how to use the accessport to do this?
Jovani is offline
post #9 of 9 Old 05-30-2013, 08:41 AM
See the guide for how to flash the ECU. Done. CEL deletion is an option in the map. You can't turn a CEL off/on just with the AP.
