my 2002 wrx - Page 2 - Subaru WRX Forum
post #16 of 43 Old 02-02-2012, 07:53 PM
Keith might drive up to new england for that kind of price.
post #17 of 43 Old 02-10-2012, 03:21 PM Thread Starter
I think that I will just find a Stock engine for now, But does anybody have any suggestion about what I should get for a stock EJ20 to be able to hold a 20G Turbo or What could I add and replace to make the engine hold up?
Rickyrum23 is offline
post #18 of 43 Old 02-10-2012, 10:26 PM
30+ thousand miles on a stock block and 20G, but of course mine is a 2.5l for what difference that makes. Its all in the tune and how well it is kept. Why a 20G, whats your goal?
post #19 of 43 Old 02-11-2012, 08:10 AM Thread Starter
Joshua,
The 20G is what I have now. I just wanted to awake the car and give a little more than what it had. I guess that I must have given it too much and now I have 2 cracked heads and part of the cylinder wall chipped away. So, now I need a new engine. Heck, I may even get the 2.5 Block and put in. I'm in the process of looking for an engine now. I just don't wanna make the same mistake twice.
post #20 of 43 Old 02-11-2012, 09:07 AM
Oh ok, got you, I must have missed or misread along the way. My apologies. At a minimum tho look it rods and pistons. Depending on the budget look into valves and that, and maybe even a better cam depending on what you are looking for out the the setup.
post #21 of 43 Old 02-14-2012, 08:07 AM Thread Starter
Joshua,
Thanks for the advice. I just found a short block that Im going to pickup this Sunday. It's out of a 04" WRX. So, at least I'll have that and then I can start working on other things. I definitely wanna add a few things to the block before I put it in. What cam, valves, rods, pistons, and even Injectors would you suggest to put in?
Ricky
post #22 of 43 Old 02-14-2012, 04:13 PM
Originally Posted by Rickyrum23 View Post
Joshua,
Ricky
Really that depends on a few things:
1) What are your goals with the car?
2) How much can your really afford to spend?
3) Read the first 2 very carefully.
post #23 of 43 Old 02-14-2012, 05:53 PM Thread Starter
PSINUSE,
My goals with this car that I have now is to be around 325-350 horse power. I don't mind spending some money, but I don't wanna go too crazy with the cash. Later on, when I get another Subbie; than I want to build that one up and make that my weekend only car.
post #24 of 43 Old 02-14-2012, 09:11 PM
Crank or wheel hp? I'd say at the most STi rods and forged pistons and you'd be okay at that power level. Injectors 750-800cc would get you there with a little head room.
post #25 of 43 Old 02-15-2012, 09:34 AM Thread Starter
Psinuse,
I would like for it to be at the Wheels, and when I take my car to the track for the 1/4 mile; I would like for it to be around the mid to high 12's. Do you think that 1200cc injectors would be too much for now? or just go with the 750-800cc ones?
Thanks
post #26 of 43 Old 02-15-2012, 09:40 AM
1200's are overkill. You should be fine with 750-800's
post #27 of 43 Old 02-15-2012, 01:19 PM Thread Starter
Gr8, Thanks. I don't want to overkill it.
post #28 of 43 Old 02-15-2012, 03:01 PM
Pffft you could hit high 12's easily on less power.
post #29 of 43 Old 02-20-2012, 02:31 PM Thread Starter
Hi guys! I just got my short block on Sunday and now I need to get a set of Heads. I was wondering if I get a set of STI heads or another 2.5 heads if it would work or would I have to change everything around.
post #30 of 43 Old 02-20-2012, 02:39 PM
Different heads are not plug and play.
