Installed Bomz Racing CAI. sits down in the fender where intake silencer used to be. First day of driving in very wet and snowey conditions. I arrived home from work and examined the 3 flare intakes in the fender. Shining bright flashlight through them reveals a limited view of the intake filter and portion of chrome tube. The tube is clearly dabbled w/water droplets and a few noticeable drops on the top of the filter. So clearly, i'm intaking water. I was told some small amounts of water will evaporate pretty instantly in the heat of the engine, but I'm concerned. How bad is this truly??? What if i shield the 3 flares from the filter so they can't directly allow spray of water onto the filter OR what if i were to seal the 3 flares off, can CAI still get air, from where though? The wonderful WHOOSHHHH!! noise the car has made since silencer was replaced w/CAI just did not seem quite as loud tonight. But of course, the wet road noise from the rear of vehicle is pretty loud and noticeable. (need to buy some dynomat)
thanks for your honest opinions and dissemination of knowledge regarding this engine issue.
note: I used black duc-tape to thoroughly seal off the bottom of the fender area-- it should receive minimal water through here (i hope).
And doesn't the bottom flare feed straight through the bottom of the fender to the brakes/wheel area? Or is that intaking water to the CAI too?
Man i don't wanna take the CAI off, even if i can modify the stock by cutting it out and using K&N. Rats!
