Max. safe boost & expected HP - Subaru WRX Forum
post #1 of 7 Old 02-03-2003, 08:56 PM Thread Starter
My friend was wondering that if he turned the boost up on his stock turbo on a 2002 WRX sedan, say about 15-17 psi, what kind of HP increase he could expect. I told him maybe 20-30 hp, but I really dunno.
-Andrew
Dsmified is offline
post #2 of 7 Old 02-04-2003, 01:21 AM
well...the way i've heard by some people, is add on about 7-8 HP per pound of boost added.
wrxwannabe is offline
post #3 of 7 Old 02-05-2003, 09:22 PM
This is from ScoobySport website:
NOTE: We caution against making a boost controller your first modification, as we literally service one engine per week in the UK that has been ruined by boosting without proper engine management. In fact, if a customer insists on an adjustable boost controller, we ask when they want to make an appointment for the engine rebuild...
Use it or lose it!
Mattr762 is offline
post #4 of 7 Old 02-16-2003, 11:30 AM
Send a message via AIM to Bubba
its very safe to alter stock boost levels with just a good boost gauge an egt gauge, a manual controller and basic tuning knowledge. 15-16 psi is probably all you want with stock fuel system and pump gas.
Bubba is offline
post #5 of 7 Old 02-18-2003, 12:20 AM
WjRgX's Avatar
Send a message via AIM to WjRgX
16 to 17 is what I will be doing but just turning it on at the track, my every day setting will sit 14 to 15, for every pound of pressure I believe is a 15 bhp gain. If you have a factory boost guage .11 I believe is around 16 PSI, but I am checking on that now, so I will reply again if I am wrong.
WjRgX is offline
post #6 of 7 Old 02-18-2003, 12:28 AM
I thought is was 8bhp. Not real sure though.
Use it or lose it!
Mattr762 is offline
post #7 of 7 Old 02-23-2003, 05:37 PM
Send a message via AIM to IMPREZvWRX
After doing some datalogging, many WRX owners have noticed the factory ECM pulling timing after ~ 15.5-16 psi, which nullifies any gain you might have made from the high boost. I also suggest using spark plugs that are one heat rhange cooler then stock to minimize any detination/misfire. A great plug to use is NGK BKR7EVX-11. I've been using these for about 20,000 miles with great results.
Chris
IMPREZvWRX is offline
