Major bogging and hesitation when giving throttle - Page 2 - Subaru WRX Forum
post #16 of 21 Old 06-03-2011, 05:39 AM
What kind of software?
post #17 of 21 Old 06-03-2011, 09:49 AM Thread Starter
2002wrxpdx is an unknown
its "ECU Flash", an open-source flashing software. I have mainly used it to deactivate DTC codes.
Anyway, PROBLEM FIXED!
Here is what I did.
1. I removed the entire fuel system from the engine bay, lines, filter, fuel rails, inejectors, regulator.
2. Cleaned all parts, blew air through all lines, blew compressed air backward through each injector while cycling it open/closed.
3. Reinstalled eveything, but I plumbed the fuel system differently. Instead of having the fuel pass through the regulator(Radium Engineering aftermarket regulator) , then through the rails, then dead-end at the number 1 injector, I now have the fuel feed going directly to driver rail, then over to passenger rail, then out of passenger rail and into the regulator and the return line connects to the regulator.
Two different ways to plumb the system. I have used the dead-end technique sucessfully in the past on some very high-horsepower cars(not subaru), never had a single issue.
So maybe I cleaned a blockage, or maybe its the new plumbing scheme. Either way, it is running smooth again. I guess I owe myself $25.
thanks for the help along the way.
2002wrxpdx is offline
post #18 of 21 Old 06-03-2011, 11:15 AM
bad grocerygetter's Avatar
Congratz. Nice work.
Kevin.
bad grocerygetter is offline
post #19 of 21 Old 01-07-2013, 05:46 PM
tommy55 is an unknown
I'm having the EXACT same issue! The only aftermarket parts I have installed is a short ram intake and new turbo inlet. Car throws no codes and I tried replacing the MAF as well.
Do you think I should do the fuel system clean or is it bad gas?
tommy55 is offline
post #20 of 21 Old 01-17-2013, 03:49 PM
TURBOTEK is an unknown
Tommy55 > the first thing I would do is test the wiring connected to the MAF and the MAP sensor, I have
had the connections break inside the pig tail or just before. Also just as previously posted, the first
question for you is: Is there a custom tune on the car currently? if the injectors are not scaled properly
then you may want to address that first before you end up wasting your time on needless testing.
-Tom@TURBOTEKTUNING.com
TURBOTEK is offline
post #21 of 21 Old 01-17-2013, 03:49 PM
when connecting the short ram / turbo inlet you may have damaged the connections
TURBOTEK is offline
