MAF and turbo - Subaru WRX Forum
post #1 of 6 Old 10-04-2010, 09:50 AM Thread Starter
MAF and turbo
If my MAF is no good would that affect the turbo??
cooner is offline
post #2 of 6 Old 10-04-2010, 09:59 AM
If your MAF is no good, your car wouldn't run. Sometimes when it's dirty, it reads inaccurately which can affect things when you have your foot down substantially.
post #3 of 6 Old 10-04-2010, 10:08 AM
but to answer your question no it wont harm the turbo
post #4 of 6 Old 10-04-2010, 11:20 AM Thread Starter
Thanks, I appreciate the responses. I am having issues with my 03 WRX, I wasn't getting any boost. I brought it into the shop and they replaced the Air/Fuel ration sensor. It was stuck at 3.7 volts. This didn't fix the issue, so they suggested that because this sensor was off that it messed with my cat in the up pipe. So I purchased a catless up pipe and replaced it yesterday. Taking off the old one, the cat was shot. So I know this was an issue. But it still didn't fix anything. I am still getting no boost. And whenever I go to completely stop and idle it stalls. Does anyone have any suggestions of what to do next??
cooner is offline
post #5 of 6 Old 10-04-2010, 11:23 AM
Check for boost/vacuum leaks
post #6 of 6 Old 10-07-2010, 07:03 PM
did you check the turbo? explain what you mean the UP cat was shot? if its shot like im thinking, the turbo sucked up a whole lot of cat pieces and you broke something. also how do you know your not getting boost? butt dyno or gauge?
