Low RPM issues - Subaru WRX Forum
post #1 of 6 Old 08-23-2011, 01:53 PM Thread Starter
rotheee's Avatar
Low RPM issues
When in low rpm's, usually when trying to take off from a dead stop my car begins to jerk. I'm not sure its the tune, or just needing new plugs or may be something i don't know. I also just had a new clutch installed, ACT Xtreme Performance Street Clutch. I pretty sure its not the gas. I run only 93 in it. It happens no matter where i get gas from and i recently used SeaFoam in the gas tank, have yet to put some in the crankcase. Sooooo any suggestions what might be causing this? anything would help! thanks
rotheee is offline
post #2 of 6 Old 08-23-2011, 03:43 PM
Could be plugs. Did you get the flywheel resurfaced correctly?
post #3 of 6 Old 08-23-2011, 05:48 PM
Or buy a new flywheel?
post #4 of 6 Old 09-05-2011, 08:21 AM Thread Starter
rotheee's Avatar
i did neither, well sort of. I bought a new insert for it. So basically its brand new.
rotheee is offline
post #5 of 6 Old 09-05-2011, 11:08 AM
Its not new if the surface isn't smooth and will not lay flat to the new clutch.
post #6 of 6 Old 09-05-2011, 03:28 PM Thread Starter
rotheee's Avatar
the only thing that come in contact with the clutch is the insert on the flywheel tho, right? or am i wrong. The insert for the flywheel was bought off of ultrarev.com
rotheee is offline
