-   -   looking to buy 18g tdo6 turbo (http://www.wrxtuners.com/forums/f52/looking-buy-18g-tdo6-turbo-24923/)
boost_556 12-12-2008 12:54 PM
just want some suggestions on this turbo, since i am looking to replace my vf39.
As u guys have seen my old post, puting down 335 whp with the vf39, but i have noticed my turbo is now smokng when the car is cold and i know it will get worse.So i am looking to replace it with the FP18G TD06 7 cm2 housing.I wanna know if i can make more power with this new setup and the same time not costing too much.Also hope it will spool nearly as quick as my old VF39.
thanks guys for any advise on this .
newtothegame 12-12-2008 02:51 PM
Check out blouchturbo.com. Send them an email asking about it, and describing what you are looking for. They are very helpful people.
boost_556 12-12-2008 05:12 PM
thanks bro i will check them up
03 CrazyTaxi 12-12-2008 05:51 PM
I see a Blouch Dominator 4 in your future.
turmic 12-12-2008 09:57 PM
It seems that crazytaxi is our swami...
newtothegame 12-12-2008 10:18 PM
Hey not a problem. I have contacted them with questions as I researched for my future and had helpful info from them, and have also heard nothing but good from them. Keep us posted as to what you get and how it goes.
Kjott21 12-12-2008 10:54 PM
The 2.0L motor is better matched with a TD05 housing. It will give you better spool. You will definitely get bigger numbers with the 18g than with the vf39.
newtothegame 12-12-2008 11:00 PM
If I recall the OP is running meth also which will assist in all that if he gets the turbo and gets a nice tune on it. Best of luck Boost.
mosc 12-13-2008 12:43 AM
TD06SL2-18G-7cm - [url=http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTSUBFP18G6SL2&Category_Code=WRX-Turbo]Forced Performance Turbochargers: Subaru FP 18G Turbocharger[/url]
Should be perfect for a meth fueled EJ205 pushing you in the 310-330whp range. A little big for standard octane EJ205s but with some more fuel potential, it's a great choice. The SL2 housing is the newest one I believe...
boost_556 12-13-2008 06:40 PM
so i checked out the blouch turbos and so there is alot of good words abt them, but their way off my budget, so i am gonna get the 18G TD06 SL2 with the 7 cm2 housing from extreme psi by ( FORCED PERFORMANCE ) for $831.00 shipped as compare to $1250 from blouch .
I was told this set up will spool abt 200 rpm later than the VF39 which is still not too much lag and will give me a good top end punch and tops out at 400 to the wheels.
Thank you guys for the input and i will keep u update on the install and tune with this new turbo.
newtothegame 12-13-2008 08:39 PM
Yeah, blouch is higher than some places I saw. Im sure you will still be happy. Looking forward to seeing this come together. Best of luck with it.
turmic 12-14-2008 01:34 PM
The price is high, but i think of it as overhead that is worth it. They'll stand behind their work if anything goes wrong, unlike most other places which will just deem it your fault, and then not replace the turbo. Seen it in other forums. I think I'll leave it at that...and not start a flame war.
WReXd 12-14-2008 01:34 PM
blouch has a better reputation, and their 18g comes port and polished (hot side) with a td06 compressor housing
isd_intrepid 12-15-2008 09:19 AM
what's the purpose of port and polishing a turbo?
turmic 12-15-2008 11:37 AM
Better flow....flow makes the ponies and trq. Not psi.
