lightweight flywheel and crank pully - Subaru WRX Forum
post #1 of 4 Old 07-09-2006, 09:04 AM Thread Starter
what are your views on running a lightweight flywheel with a lightweight crank pulley. I have a ACT flywheel now and was thinking about getting a perrin pulley are their any advantages having both or should i just stick with my flywheel?
dewrx02 is offline
post #2 of 4 Old 07-10-2006, 05:50 AM
Most people will tell you not to both as the car does need a certain amount of rotating mass.. However, I have the ACT Street Light Flywheel and the Perrin Light Weight Crank Pulley on my car with no issues.. With the Speed Sensor not registering (Hydra wiring harness was off 1 pin) I had issues with the car stalling when slowing to a stop, but once I got the wiring diagram and fixed the speed sensor I have had no issues..
In case your wondering, when the EMS registers the Speed Sensor signal that the car is slowing and you apply the clutch the EMS "blips" the throttle to keep the car from stalling.. Short and ugly explanation but works...
post #3 of 4 Old 07-10-2006, 03:24 PM
oldfartracer's Avatar
On most 02-03, without a stand alone, you will throw a CEL with both. I run the crank pulley, but the not the fly wheel. What are your plans for the car?
oldfartracer is offline
post #4 of 4 Old 07-10-2006, 07:56 PM Thread Starter
well i don't know how much i can get out of my setup i have. Im runnin a vf30 with pinks and pump,a utec i have perrin rails sittin here don't know if i need them i was tuned at turboxs 2 months ago 300whp, have the lightweight flywheel and having ra gears installed as we speak,i just don't want to screw up what i have by putting that pulley on.
dewrx02 is offline
