Lightweight flywheel - Subaru WRX Forum
post #1 of 29 Old 10-04-2005, 02:07 PM Thread Starter
rich8669 is an unknown
Will a light wieght flywheel increase spool up time and sooner in the rpm range?
rich8669 is offline
post #2 of 29 Old 10-04-2005, 02:27 PM
dopekidz's Avatar
dopekidz is an unknown
yes it will cause there's less mass to rotate...
dopekidz is offline
post #3 of 29 Old 10-04-2005, 04:08 PM
Nose Nuggets's Avatar
spool time on what?
it will rev faster, i dont think it will spool the turbo any faster
Nose Nuggets is offline
post #4 of 29 Old 10-04-2005, 08:50 PM
fuapiti's Avatar
Originally Posted by Nose Nuggets
spool time on what?
I don't get it, if the engine is getting sooner to the rpms where the turbo kicks in or where the boost peaks out, shouldn't the turbo do its thing just as soon?
fuapiti is offline
post #5 of 29 Old 10-04-2005, 09:02 PM
Technically the turbo is spooling the same amount at the same time if you look at it alone. I guess you could think of it as a whole and see you'd get to the RPM's faster thus the turbo acting sooner.
I think he's just trying to not confusing him by making him think that the turbo will spool faster.
post #6 of 29 Old 10-04-2005, 09:46 PM
fuapiti's Avatar
but it will...
fuapiti is offline
post #7 of 29 Old 10-04-2005, 10:42 PM
nick4592's Avatar
Yes.....roosters cannot fly
Lighter Engine parts will result in the engine and it's components to work faster and harder....
nick4592 is offline
post #8 of 29 Old 10-05-2005, 12:07 PM Thread Starter
What else can free up some rev speed.
rich8669 is offline
post #9 of 29 Old 10-05-2005, 02:26 PM
nick4592's Avatar
to make your engine run faster (which isn't that good for it) Pulleys and closer gear ratio on your tranny are things off the top of my head. Just making moving parts lighter will do the job you are looking for.
nick4592 is offline
post #10 of 29 Old 10-06-2005, 01:38 PM Thread Starter
Not faster. I am trying to get it to rev QUICKER. There is a difference. Faster would mean a higher rpm.
rich8669 is offline
post #11 of 29 Old 10-06-2005, 02:35 PM
woznin49's Avatar
woznin49 is an unknown
those two things will make "quicker". smaller pullies make it easier to spin than the larger and heavier factory pieces thus, the engine doesnt have two work harder to spin all the assesories. Closer gear ratio gives you a higher gear reduction causing the engine to build rpms faster... i mean quicker.
If you wanted it to spin at higher rpms you would have to balance your internals to a higher rpm, valve springs would have to be stronger, rev limit changed etc, etc. no real reason to do all that though, unless its strickly race.
woznin49 is offline
post #12 of 29 Old 10-06-2005, 03:01 PM Thread Starter
I was trying to correct him on his wording by saying that I wanted quicker not faster.
rich8669 is offline
post #13 of 29 Old 10-06-2005, 03:16 PM
woznin49's Avatar
ahhh
woznin49 is offline
post #14 of 29 Old 10-06-2005, 03:53 PM
herm..
well, my boost isent adjusted soly by the rpm my engine is at. if im not giving it at least half throttle, i dont get boost. just becuase its at x rpm, does not meen the engine is pushing out enough exhaust to get the turbo going.
post #15 of 29 Old 10-06-2005, 03:56 PM
nick4592's Avatar
You must have been an English teachers dream
Grammer Queen
!Laugh!
nick4592 is offline
