Lightweight Flywheel - Subaru WRX Forum
post #1 of 12 Old 10-12-2003, 10:39 AM Thread Starter
WRXblurr's Avatar
WRXblurr is an unknown
I was wondering what you guys think about the Unorthodox Racing Lightweight Flywheel. Is it worth the money or is it just a waste. Iam buying an sti clutch and was wondering if i should upgrade the flywheel to.
WRXblurr is offline
post #2 of 12 Old 10-12-2003, 10:44 AM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
Lightweight flywheels are nice, because they take a large amount of load off of the engine, so then you are able to get much better response. However, you'll experience much worse low speed driving, and will probably have to feather the clutch to get it smooth. Also, I think if the flywheel is less than 9.5 lbs then your ECU won't know how to react, and you will lessen your performance. (something I heard, I have no real experience with that)
Blue
BlueDemon is offline
post #3 of 12 Old 10-20-2003, 03:58 PM
midnght's Avatar
midnght is an unknown
They will also fall off fast, rpms I mean. The rpm drop is also going to do thing s to your boost. The faster you fall the longer it will take to catch back up. I am not saying it is a bad thing because it will catch up faster being it is 'lightweight' and all. Lighten fywheels need more tuning to get the full effect going.
Put it this way, a buddy of mine ran a 13.3 before the install of a lightweight flywheel. After the install he ran a 13.5. He is pretty consistant on the track and can go through the gears like the best of them. He just couldn't get that .2 tenths back to save his live. We are guessing it is because of the faster rpm falloff.
I have never heard of the ecu not knowing how to react to the new flywheel. I guess it is more of a subie thing?
Hope I helped.
midnght is offline
post #4 of 12 Old 10-20-2003, 04:52 PM
fc735's Avatar
no..the knock sensor is pickin up more harmonics, detecting them as knock...and pulling timing. this is esp true with cars running a light fly and crank pulley. there are more crank shocks going throught ht eblock,....ie..more harmonics. fooling the knock sensor...pulling timing.
does this on most all boxer engines.
fc735 is offline
post #5 of 12 Old 10-20-2003, 08:34 PM
midnght's Avatar
Thanks for the info.
Are the crank pulleys harmonic dampned or not on the WRX? That is my problem right now with my dsm. The crankpulley has seperated itself from the rubber<-->metal. Another DSM problem!!
midnght is offline
post #6 of 12 Old 10-20-2003, 08:45 PM
BlueDemon's Avatar
Yes, the stock crank pully on the WRX is harmonic dampned. People sometimes have problems when they buy a lightened pully, as almost all of them have no dampening. Because of that, they are seeing their knock sensor pick up more knock, thus the ECU pulls timing, and they are getting reduced performance from something that was supposed to give them more.
Blue
post #7 of 12 Old 10-21-2003, 05:52 PM
midnght's Avatar
Blue
Yeah, that is the problem I am gathering from most people with any car. When you go from a harmonic dampned pulley to a solid aluminum pulley they are not getting the results they were expecting. It would stem from them not be able to control the excess KNOCK the engine is now producing.
It is sort of a nessesary EVIL, it is a horrible design (rubber surrounded by metal) but any other pulley is going to shake the hell out of the engine enough to register higher knock count. I personally don't see the great tradeoff for a lightend pulley.
Thanks for the help BLUE!!
midnght is offline
post #8 of 12 Old 10-21-2003, 09:56 PM
BlueDemon's Avatar
Welcome!
I have heard claims that GFB (I think) makes a harmonic dampened lightened crank pully.... (wouldn't it be nice if that was true??) It's worth looking into. (Though I don't know if they make one for your car)
Blue
post #9 of 12 Old 10-21-2003, 10:19 PM
midnght's Avatar
I don't know either, the only one I know of for my car cost $300 and is considerably more than the stock. I just don't see the point in it though. The tradeoff is not worth the big bucks. I have put alot in this car, as I will with the WRX once I get the deal done.
Chad
midnght is offline
post #10 of 12 Old 08-19-2008, 09:07 PM
temallica1 is an unknown
Hope I helped.
do you know how light that flywheel was? im looking at getting a 13.9 lb flywheel.
temallica1 is offline
post #11 of 12 Old 08-19-2008, 09:56 PM
considering this thread is like 5 years old, i dont think he is going to answer you.
nagyhead is offline
post #12 of 12 Old 08-19-2008, 10:51 PM
lol thanks
