Larger TMIC problem HELP! - Subaru WRX Forum
post #1 of 10 Old 07-17-2006, 12:30 AM Thread Starter
scoobnoob is an unknown
I got a larger tmic for my wrx. For some reason when it is on the car almost stalls when you turn the car on and when you drive the car the engine idles hard and when you come to a stop it almost stalls as well. The mods on my car are a turboback exhaust, uppipe and the cobb stage 2 tune. Is it because the turbo is stock or is it because there could be a leak? I checked all the clamps and i couldnt hear any air comming out but I dont know.
any help would be great. Thanks.
scoobnoob is offline
post #2 of 10 Old 07-17-2006, 12:34 AM
need2boost's Avatar
need2boost is an unknown
sounds like you have a boost leak/vacuum leak, recheck all connections for your intercooler including BOV mount, I'm almost willing to bet that you have a leak somewhere in your system. make a boost leak tester if you have to, that will pinpoint your leak.
need2boost is offline
post #3 of 10 Old 07-17-2006, 02:39 AM
awd>fwd's Avatar
awd>fwd is an unknown
Did you upgrade the hoses? It almost sounds like your hose isn't connected...
Brent
awd>fwd is offline
post #4 of 10 Old 07-17-2006, 02:14 PM
9d2TSi's Avatar
I'm willing to bet it's a leak as well. Check your IC piping again.
9d2TSi is offline
post #5 of 10 Old 07-17-2006, 02:38 PM
six3jag's Avatar
six3jag is an unknown
Send a message via AIM to six3jag
Leak. When i did this i noticed the hose from the throttle to the IC tends to get pinched on the bottom side. same for the hose to turbo connection. I would bet one of those is it.
Jacob
Almost clean wrx...
six3jag is offline
post #6 of 10 Old 07-17-2006, 02:57 PM
JiveMasterT's Avatar
JiveMasterT is more helpful than not
Definitely a leak. Check it.
Patrick - 2007 STi Limited
▼SbiΣ Mi▼
JiveMasterT is offline
post #7 of 10 Old 07-17-2006, 03:43 PM Thread Starter
I found the leak. Thank you guys for the help . Problem Solved.
post #8 of 10 Old 07-17-2006, 03:44 PM Thread Starter
It was the hose to the turbo. Thanks for the advice.
post #9 of 10 Old 07-17-2006, 04:05 PM
You guys are so smart. WRX love everyone
post #10 of 10 Old 07-17-2006, 04:20 PM
shamrock is an unknown
Well done
_Ryan_
2004 Wrb "BUGEYE"
http://www.misubie.com/
shamrock is offline
