Joe-p MBC help
I read a lotabout the Joe-p MBc, and the install wasn't a problem at all (I think)
I have an insane about of boost in all my gears now. 1st-3rd gear the turbo finally releases at .15mpa. I know something is wrong. I tried everything to adjust the mbc. I unscrewed the screw until it came out and staryted from there. Still the same problem. I tried adjusting with the screw all the way in, nothing, still the same problem.
Are you only supposed to use the MBC on a stock car? I have a unichip at Stage 1 right now. Is there something wrong with the MBC, or is it my chip that is causing this?
What is strange is that my EGT gauge wasn't giving me any sort of high readings with all the boost I was running . When the car hit .15 mpa, I only got a 1200F reading on my EGT.
The bottom of the MBC goes to the turbo, the side of the MBC goes to the wastegate. I checked this about 10 times.
I love the amount of boost, but I know I am probably killing my turbo. I took the MBC out until I know what is wrong.
Thanks for the help!!!!
It is only called speeding if you get caught!!
Visit: http://www.silverwrx.com
