I have a 2003 WRX. I'm pretty new to WRX's, especially exhaust. I'm looking to get a downpipe. Will the Invidia WRX STI V2 bolt to stock midpipe or does it replace the midpipe? I'm looking to just replace to stock downpipe right now to keep to second cat. Any advice would be greatly appreciated.
Tim
If you decide you want to autoX with it. make sure you get the one with the CAT in it. otherwise you will wind up in a racing class that you won't want to be in.
And yes the down pipe replaces the stock mid pipe. so you go from a 2 piece to 1 piece.
And if god willing. everything should line up correctly with your cat-back
Perrin makes a DP that just replaces the stock DP while retaining the stock mid pipe. It is only available with a cat so you will still have two, one of which is a low flowing stock cat. That and the $350 price tag means it might not be right for you. I got an invidia v4 catted and divorced DP and I am happy with the performance and the reduced green house gases I am spewing compared to no cat.
Most of the power increase comes from the down pipe. Power wise a down pipe and an up pipe will give you more than a turbo back exhaust. The boxer growl is better with the turbo back so I say get all of the above (up, down, cat back).
