intercooler gasket - Subaru WRX Forum
post #1 of 6 Old 02-07-2008, 09:44 AM Thread Starter
intercooler gasket
Hey guys, i took off of work today and was a lil bored. So i did the throttle body coolant bypass only took about 30 mins pretty simple. Will i notice any difference beside anger after a cold start?? My question is when i took the intercooler off i noticed there was no gaskets between the metal ends on the Y pipe and the intercooler. Should there be 2 gaskets in there???? I always thought when you were putting two metal parts together to hold water or air their needs to be gaskets??
awdturb is offline
post #2 of 6 Old 02-07-2008, 10:15 AM
there should be gaskets between the 2. you can use high temp silicone gasket maker, which you can find at your local auto store, or get new ones from the dealer.
nagyhead is offline
post #3 of 6 Old 02-07-2008, 10:45 AM Thread Starter
man, i knew it. i bought the car used with 50,000 and i find these little things all the time. How about the bypass should i notice anything from this???
awdturb is offline
post #4 of 6 Old 02-07-2008, 10:46 AM Thread Starter
Do you think the gaskets are a dealer only part or can i find them at the local stores like autozone or pep boys???
awdturb is offline
post #5 of 6 Old 02-07-2008, 03:14 PM
high temp RTV works fine
dstnbmxvr6 is offline
post #6 of 6 Old 02-08-2008, 10:11 AM
you should notice nothing from the bypass mod, not sure why people even do it.
nagyhead is offline
