Intake Options - Page 3 - Subaru WRX Forum
post #31 of 38 Old 10-23-2005, 06:11 PM Thread Starter
WRXnewbie is an unknown
how do i delete them
WRXnewbie is offline
post #32 of 38 Old 10-23-2005, 06:47 PM
nick4592's Avatar
Don't do it yourself.
nick4592 is offline
post #33 of 38 Old 10-27-2005, 09:16 AM
Originally Posted by WRXnewbie
what do you mean sucking air from the wheel well and "to each their own"? your leaving the tube that connects into the engine compartment from the wheel well right?
This is what i did instead of leaving just a hole.It's a 4" turbo bellmouth that cost me $25 of ebay.At the begining of the opening it's 5" and tapers down.Alot of people on other forums are using a 3" velocity stack from Summit Racing.Also seen plastic ones at da PEPboys.I had to trim the bellmouth to fit the radius of the fender well and at the poening of the air box but it sounds great.Much better than the elbow because the elbow I.D. is 2.5" and is alonger air tract.Also adding the velicty stack works in tandum with the stock velocity stack infront of the MAF in the airbox.If anybody decides to try this you have to reset your ECU before driving the car.
dumdum is offline
post #34 of 38 Old 10-27-2005, 10:00 AM
iwantone is an unknown
Send a message via AIM to iwantone
how do you go about reseting your ecu? just take the negative battery terminal off for a couple seconds? or am i way off and you need to send it somewhere to send it in?
iwantone is offline
post #35 of 38 Old 10-27-2005, 12:23 PM
First way you mentioned is resetting, but you probably need to wait more than a couple of seconds. Or just depress the brake. The 2nd is a reflash.
post #36 of 38 Old 10-27-2005, 01:24 PM
DEMENTED's Avatar
DEMENTED is an unknown
if you remove the elbow and leave the intake box open, wont it suck up more dirt? im guessin alot of debri and dirt might circulate near the fender and that hole might be a good entry point for the particles to be sucked up.. especially at WOT
DEMENTED is offline
post #37 of 38 Old 10-27-2005, 05:17 PM
I don't think the engine is going to create enough suction to do that! Plus thats what you have a filter for.You don't think the front air scoop would pick up just as much dirt?I don't think ther would be any difference.
dumdum is offline
post #38 of 38 Old 10-28-2005, 01:19 AM
DEMENTED's Avatar
good point.
DEMENTED is offline
