Install $$ - Page 2 - Subaru WRX Forum
post #16 of 19 Old 02-28-2008, 12:02 PM
ColoWRXer's Avatar
ColoWRXer is more helpful than not
+1 for doing it yourself. of course time and location is a factor, but if you have a day or 2 and some hand tools you can do it all yourslef....the only labor i've ever paid for is alignments and mount and balance on tires....i even do brake bleeding by myself hahaah, a 2x4 works just as well as your buddys right leg.
ColoWRXer is offline
post #17 of 19 Old 02-28-2008, 12:38 PM
Originally Posted by SUBY777 View Post
those spark plugs have nos in them.LOL. HOW DO YOU RUN A 9.0 IN 1/8TH AND A 9.999 IN THE 1/4.LMAO.
obviously he has a saturn 5 rocket in the trunk that he fires as he hits the half way point DUH!
post #18 of 19 Old 02-28-2008, 06:56 PM
Honestly I would suggest that you do it your self as well. The Down tube, Up-Pipe, and header are all pretty straight forward you really can't mess it up.. The hardest part of their install is removing and reinstalling the Up-Pipe. As for the inlet, depending on the type one doesn't always have to remove the inlet to install one.. Personally I was not real happy with the Perrin inlet. It was a little bit of a PITA to put it in, however it was doable with minor mechanical knowledge..
post #19 of 19 Old 02-28-2008, 10:00 PM
... And alot of lube, I sprayed mine with silicone spray before i slid mine in.
nagyhead is offline
