Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-On Tech (EJ205 2.0L '02-05 WRX)
Old 02-18-2007, 03:59 PM   #31 (permalink)
Car: 05 WRX
Reputation: Black Night is an unknown
Send a message via AIM to Black Night
is there a reason that the VF-23 is called the secret weapon?
[webpage] [posts] Reply With Quote
Old 02-18-2007, 05:05 PM   #32 (permalink)
suddenthomas's Avatar
Reputation: suddenthomas is more helpful than not
Originally Posted by dumdum View Post
Only the VF36,VF37,VF38 and VF42 are twin scrolls.The VF23 is not,but it is a roller bearing turbo. The VF23 uses the same P20 turbine housing that the VF22 uses,which is not a twin scroll design.
So really they are just a newer version of the vf22?
Old 02-18-2007, 05:12 PM   #33 (permalink)
The fact that they are a roller bearing design with a compressor bigger than the VF30/VF34 and spool up faster than a VF22 and probably a VF30 makes it a pretty potent turbo.I like the VF24 as well.
Aarg matey!
ECU Pirated by RomRaider
Old 02-18-2007, 05:14 PM   #34 (permalink)
Which turbo are you running DUMDUM?
Old 02-18-2007, 05:25 PM   #35 (permalink)
Ported and polished stocker right now.Needed to make some dough so the bigger turbo had to go!
Aarg matey!
Old 02-18-2007, 06:55 PM   #36 (permalink)
Also three more VF series turbos not one the original list:
IHI VF43
(250-325whp, Bolt-On)
This is the standard equipment turbocharger used on the MY07 USDM Subaru Impreza WRX STI. It can be found on both base STI's and STI Limited's. The VF43 utilizes a thrust bearing design and the P15 exhaust housing. The difference between the VF43 and the VF39 used previously on STI's is the size of the wastegate. The VF43 has a larger wastegate designed to reduce boost creep issues.
Expect to achieve full boost with the proper mods and a quality tune between 3000-3500rpms
IHI VF40
This is the standard equipment turbocharger used on the USDM Subaru Legacy GT. It can be found on all the current model years from 2005-2007.
IHI VF41
This is the standard equipment turbocharger used on the JDM Subaru Forester STI. It utilizes a P18 exhaust housing.
Aarg matey!
Old 02-18-2007, 08:04 PM   #37 (permalink)
Club Region: SoCal
Trader Rating: (1)
Reputation: WReXd is known to be trustworthy and helpful WReXd is known to be trustworthy and helpful
This guy's apparently selling a vf48...??? http://www.thepartstrader.com/forum/...24510#msg24510
Old 02-19-2007, 07:47 AM   #38 (permalink)
Apparently its an old turbo that used to come on some of the 1.8L turbocharged Subaru's (GL10).Its also known as a VJ11.Very tiny!I actually have one in my garage that i was porting!
Aarg matey!
Old 03-16-2008, 12:09 PM   #39 (permalink)
VD5505's Avatar
Reputation: VD5505 is known to be trustworthy and helpful VD5505 is known to be trustworthy and helpful VD5505 is known to be trustworthy and helpful
I just put a VF22 on my 03 and i love it, it does take a little longer to spool up but its worth it in the long run i think. great info on the turbos by the way!!!!
Old 03-16-2008, 06:59 PM   #40 (permalink)
Now there is a "new" VF48.Comes on the 2008 STi's.Basicly the same thing as a VF43 but uses a new 5 arc compressor design.
Aarg matey!
Old 04-14-2008, 12:21 AM   #41 (permalink)
tom_noland's Avatar
Reputation: tom_noland is an unknown
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
Does anyone know what size injectors to use with a TD05H-Big 16G Turbocharger? What about fuel pump size too?
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
RIP baby....Here I come STi.
Stupid deer.
Old 04-14-2008, 01:08 AM   #42 (permalink)
wrxman420's Avatar
Reputation: wrxman420 is more helpful than not
I would say get some 650cc injectors. Also a warlbo 255lph fuel pump will work. Has anyone over here ever heard of the IHI VF48 turbo. I have been reading over on nasioc and it comes on the 08 STi's. It has comparable numbers to an 18G.
Old 04-14-2008, 01:53 AM   #43 (permalink)
tom_noland's Avatar
thanks man
Another question. Would a big 16g run well with a TMIC? Not the stocker, but an aftermarket bigger TMIC.
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
Stupid deer.
Old 04-14-2008, 02:08 AM   #44 (permalink)
tom_noland's Avatar
I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post!
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
Stupid deer.
Old 04-14-2008, 03:42 AM   #45 (permalink)
Black05WRX's Avatar
Car: 05 WRX
Reputation: Black05WRX is an unknown
Oh ya, your still able to cool the air charge...
