Hyper Ground System - Subaru WRX Forum
post #1 of 19 Old 03-07-2003, 06:47 PM Thread Starter
beanswrx is an unknown
Hyper Ground System
any one have a grounding system? hp gains? ground points? thinkin about doing it, i've only heard good about it, thanks for any help
beanswrx is offline
post #2 of 19 Old 03-08-2003, 11:53 AM
JRock is an unknown
I was told it can make a big diff. so after looking at hks website and seeing what it did for other cars......focus 5hp whp......supra 20whp....etc. I ordered it, so i'll tell you how it does after I install it.
JRock is offline
post #3 of 19 Old 03-08-2003, 03:43 PM
QuickShift is an unknown
i have it on mine it does help some wut , i have felt a little better response out of the engine.
QuickShift is offline
post #4 of 19 Old 03-08-2003, 05:28 PM
koki is an unknown
i have read about it ,is it a universal set or a specific for the soobies ??what does the kit conssist of? i read that you need to fool arround w it to get the best results? how much is it ?
koki is offline
post #5 of 19 Old 03-09-2003, 01:00 PM Thread Starter
there are 3 diffrent sets: small medium and large. universal, kits has every thing needed to make the grounds, you do have to test diffrent points on the car to get the best results, thats not to hard to do, and the cost is $98.50-$143.50.
quickshift,
what ground points did you use? nad how long did it take for you to install,
thanks
beanswrx is offline
post #6 of 19 Old 03-10-2003, 09:43 PM
ljasonl is an unknown
Send a message via AIM to ljasonl
or you can just buy some 10 guage wire and ring cap for about $10
ljasonl is offline
post #7 of 19 Old 03-10-2003, 09:58 PM
TrboChgd is an unknown
Plus It looks really good
"natural is nice but i'd rather be forced and blown"
TrboChgd is offline
post #8 of 19 Old 03-12-2003, 07:15 PM
koki is an unknown
il go w jason whats the gauge of the hypergroung system?
koki is offline
post #9 of 19 Old 03-12-2003, 08:41 PM
Gerlando is an unknown
What?! Damn that sounds expensive for some wiring. You'd think they were made by Monster Cable!
You can piece together the parts you need for less then $10 easily. As for results, some people swear by it, others think it's snake oil. I've got one ground on my car from the block to body and battery ground but I honestly don't know if it made a difference. If you spend $100 for wires you'll subconciously make yourself feel a difference. Hell, I would.
-Gerlando.
<a href=
href=http://www.enjoychuck.com>EnjoyChuck</a>
Gerlando is offline
post #10 of 19 Old 03-13-2003, 05:08 PM
IMPREZvWRX is an unknown
Send a message via AIM to IMPREZvWRX
I used Monster 4AWG to make my own Hyper Ground system. I had a couple feet left over from running my battery wire to the trunk. Don't count on it making a difference you can feel. Not worth $100 or whatever they charge, I don't care what it looks like.
Chris
IMPREZvWRX is offline
post #11 of 19 Old 03-14-2003, 05:40 PM
Suspended
conejo is an unknown
Send a message via AIM to conejo
HEY , IF U BUY IT , TELL ME WHAT IT DID AND HOW MUCH OF A DIFFERANCE IT MADE
I THINK ITS TOO EXPENSIVE FOR JUST WIRES FROM JAPAN.
BUT IF IT WORKS GOOD ITS WORTH IT ON A BRAND NEW CAR.
I DONT KNOW #@%#@%#@%#@% ABOUT WIRING , SO I DONT KNOW HOW TO HOOK IT UP I APPRECIATE ANY ADVISE
conejo is offline
post #12 of 19 Old 03-15-2003, 12:17 AM
Just run wires from your negative battery terminal to randon metal parts under teh hood. One big one will do, but do what you want.
Chris
post #13 of 19 Old 03-15-2003, 04:09 PM
Suspended
i should unplug the negative terminal always first right?
and plug back the positive first , then negative?
conejo is offline
post #14 of 19 Old 03-15-2003, 11:03 PM
Correct. For this mod, you don't have to remove ther terminal, just loosen the nut so you can out the new wires on.
Chris
post #15 of 19 Old 03-25-2003, 07:08 PM
mOmOsAuR is an unknown
Go HKS circle earth all the way 130 bucks..cant go wrong
mOmOsAuR is offline
