Old 05-01-2008, 08:36 PM   #1 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
Hybrid Question
Well i took my car and put it on the dyno yesterday and my engine we found out is going bad i only have 40k on it and one of my cylinders are down, anyways i bought a STI short block and im putting my 2.0 heads on it, i was wondering how this runs on performance whys the tuner was saying how they are very good engine on making Tq and then he said that they have no higher end power, but i was wondering like how bad of a higher end do they have if i use my stock 2.0 cams in there. im in a hurry typing this i hope it made sense thanks alot guys.
Old 05-01-2008, 09:10 PM   #2 (permalink)
Jave's Avatar
Car: 04 WRX
Timeslip: 9.999 @ 106.14
Trader Rating: (3)
Reputation: Jave is more helpful than not
I have no clue as to why your tuner thinks you have no more high end power. I have stock 2.0l heads with a PnP and stock internals on my hybrid and I am putting out way more power. Maybe he is thinking that you are going to reuse your TD04.
▼SùbiΣ Mäƒiä▼
Old 05-01-2008, 09:24 PM   #3 (permalink)
VD5505's Avatar
well what i think he means i will get alot more higher range power say if i would put sti cams in it or some other type of cams other than my stock cams, what were your numbers you made
Old 05-01-2008, 10:27 PM   #4 (permalink)
Jave's Avatar
Car: 04 WRX
Trader Rating: (3)
I live about 400 miles form a dyno so no clue. I am not fully tuned yet and maxing out my MAF at only 17psi and still ran a 12.84 on stock tranny.
▼SùbiΣ Mäƒiä▼
Old 05-02-2008, 01:36 AM   #5 (permalink)
VD5505's Avatar
i ran that on my stock TD04 i was running that engine hard with that stock turbo i ran a 8.01 in the 1/8 with a 1.61 60ft
Old 05-02-2008, 12:21 PM   #6 (permalink)
VD5505's Avatar
you think i should get cams for it or stay with my stock ones
Old 05-02-2008, 12:24 PM   #7 (permalink)
Jave's Avatar
Car: 04 WRX
Trader Rating: (3)
comes down to budget, if you can afford go aftermarket. Those are good times but the turbo I am running can push way more PSI but I need to get a 70mm housing or go to a denstiy setup to get away form MAF readings(but dont have the funds).
▼SùbiΣ Mäƒiä▼
Old 05-02-2008, 02:09 PM   #8 (permalink)
VD5505's Avatar
how much does that cost for you to do that??
Old 05-02-2008, 03:47 PM   #9 (permalink)
Jave's Avatar
Car: 04 WRX
Trader Rating: (3)
to go Density I need a new ECU like a Hydra or buy a UTEC. Not with in my budget compaired to a temporary fix of just going with a bigger MAF housing but I need to get tuned for that as well.
▼SùbiΣ Mäƒiä▼
