hp/torque difference? - Subaru WRX Forum
post #1 of 24 Old 10-08-2004, 11:52 AM Thread Starter
wags528's Avatar
wags528 is an unknown
Send a message via AIM to wags528
vf34 turbo, fmic, sti injectors, walbro fuel pump, aftermarket upipe, utec, greddy evo2 catback . . . .
would there be a big difference in hp/torque if i have a stock downpipe with the above setup as opposed to an aftermarket downpipe . . . . the reason i am asking is because the emmission regulations are strict here in PA and i don't want to have to deal with swapping out exhaust parts every year so i was planning on leaving the stock downpipe as is and just replacing the uppipe (so that i can up the boost) . . . .
wags528 is offline
post #2 of 24 Old 10-08-2004, 12:11 PM
lobsterhat's Avatar
Images: 15
lobsterhat is an unknown
My only quick educated guess would be it would be harder to spool your turbo since there will be more restrictions on your exhaust flow leaving the turbo. Maybe you can't make as much boost?
lobsterhat is offline
post #3 of 24 Old 10-08-2004, 02:25 PM
bah14's Avatar
bah14 is an unknown
from what i have seen, most downpipe swaps yeild considerable hp/trq gains.
"I hear Buschur Racing does WRX UTECs now ... oh buddy!"
bah14 is offline
post #4 of 24 Old 10-08-2004, 03:41 PM
blackie's Avatar
blackie is an unknown
the replacement of the down pipe is a must if you want power.
blackie is offline
post #5 of 24 Old 10-08-2004, 06:01 PM
IBAUCLAPlaya's Avatar
Yeah many you need that or else the turbo is gonna have crazy backpressure which isn't good. Get a DP w/ a cat. TXS, Stromung, Helix, etc.
IBAUCLAPlaya is offline
post #6 of 24 Old 10-08-2004, 07:38 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Deffinitly, at least get a down pipe with a cat. if your doing a turbo and fuel up grade you need a down pipe and with a good tune and a down pipe with a cat you should be fine
Ian is offline
post #7 of 24 Old 10-09-2004, 05:36 PM Thread Starter
wags528's Avatar
so if i went with a bosal or stromung dp this would leave the stock midpipe (cat) . . . this would then be safe with those upgrades? . . . . will i still be able to pass emmissions testing?
wags528 is offline
post #8 of 24 Old 10-10-2004, 01:42 PM
Ian
Ian's Avatar
You should be able to get a complete down pipe with a built in high flow cat and with a good tune be able to pass
Ian is offline
post #9 of 24 Old 10-10-2004, 04:04 PM Thread Starter
wags528's Avatar
i was looking at the exhaust diagram that is in Kobi's modification guide and see that the rear O2 sensor is in the stock midpipe (cat) . . . if i just replace the actual downpipe and leave the stock midpipe, will that still cause a CEL?
wags528 is offline
post #10 of 24 Old 10-10-2004, 08:10 PM
It might, it might not. All it takes is one bad blast of air to set it off.
post #11 of 24 Old 10-11-2004, 09:51 AM
RPFRIDE's Avatar
RPFRIDE is an unknown
I dont think inspection is very strict in pa.
No sniff test if you pass computer test. They MIGHT do visual but get "friendly" with youre inspection garage.
RPFRIDE is offline
post #12 of 24 Old 10-11-2004, 09:55 AM
RPFRIDE's Avatar
also, there's no engine mgmt in you list on mods?
Cobb a.p. will delete cels involved with stage 3 and obd (?)computer will pass you at inspection.
sorry utech.
RPFRIDE is offline
post #13 of 24 Old 10-12-2004, 03:22 PM
Bullit's Avatar
Bullit is an unknown
This is what you do. Go ahead and get the exhaust setup that you want. But when you do it, get a check engine light fix. If the light doesn't go off, to their computers technically there is no error, so it won't throw their monitors off. I have friends that have done that, and have no problem with emissions. And their cars definitly aren't legal. But this all depends on how they do things in PA. Make sure that they plug the car up and not check exhaust. They usually just plug the car up, and it checks for error and engine light trips.
Bullit is offline
post #14 of 24 Old 10-12-2004, 03:36 PM
Cosmo's Avatar
Images: 15
Well, if you can work a wrench, you can change a downpipe. I can change one in about 15 minutes. 7 bolts and an O2 sensor.
Cosmo is offline
post #15 of 24 Old 10-12-2004, 04:47 PM
Bullit's Avatar
Sh!t, in 15 minutes! I need you when I get mine. I'm just worried about too much heat from the downpipe without a heat shield.
Bullit is offline
