Hot exhaust after turbo upgrade - Page 3 - Subaru WRX Forum
 15Likes
post #31 of 37 Old 08-06-2013, 08:59 PM
Lol. I pays to ask the what should be obvious questions first unless stated in the OP.
post #32 of 37 Old 04-29-2014, 06:44 PM Thread Starter
bugeye03 is an unknown
Good news, car stills runs great
bugeye03 is offline
post #33 of 37 Old 04-29-2014, 06:55 PM Thread Starter
I managed to avoid spending 10-15K...i decided to not go with 24k gold plate everything and went with used items..i do appreciate the bashing, and i appreciate the help. i got enough support mods to make sure she runs healthy. eventually a new motor, for now shes perfect.
bugeye03 is offline
post #34 of 37 Old 04-30-2014, 01:28 PM
Please list your current mod list.
post #35 of 37 Old 04-30-2014, 09:11 PM Thread Starter
as i said i have enough support mods, probably not everything.
what i can think of off the top of my head is...
3" catback HKS sport
3" invidia Bellmout catless Down pipe
ATP GT30 Garrett Turbo stock location
Catlest uppipe 3-bolt
Equal length headers
Walbro 255
ID 1000cc injectors
Sti TMIC intercooler W/ Synapse Diverter Valve
Grimmspeed 3-port boost controller
6" AEM dry filter cone on short ram intake
Protune with cobb AP
I run amsoil OE series since i change oil frequently
Havent had any heating issues....knock on wood
She eats oil..trying to figure that out.
For my original post i ended up doing the resistor trick and putting a bolt in there. apparently that code only exist to protect the cat in the uppipe, which i dont need to worry about.
bugeye03 is offline
post #36 of 37 Old 05-01-2014, 10:33 AM
STI TMIC is a bit too small for a turbo that size. Once you get to 20G sized turbos (yours is bigger) they get to be restrictive and you need to go with a larger and freer flowing core.
What bout engine and transmission builds? This turbo is much larger than what you should be running on the stock bits components if you're using it anywhere close to its potential. That makes up most of the budget I mentioned.
post #37 of 37 Old 05-01-2014, 05:14 PM
GSMNZ's Avatar
Did you get this dyno'd at the same time of the protune? What are you getting for HP/TQ if so?
GSMNZ is offline
