HELP!!! Smoking turbo why? - Subaru WRX Forum
post #1 of 7 Old 06-03-2010, 08:24 PM Thread Starter
03sonicyWrX is an unknown
Send a message via AIM to 03sonicyWrX
Ok, so here is the deal....
I replaced the turbo and put a vf30 on which i purchased from someone through a forum and he said it only has 5k on the turbo, looking at it it was on awesome condition no shaft play, very clean. And running a bigger turbo i purchased 660cc injectors, ported and polished intake manifold and throttle body, and tgv valve delete. After setting it all up, i knew my tune would be terrible from a stock turbo, and i do have all supporting mods. But after starting the car up it's very shaky and goes into limp mode almost turning itself off. My AF ratio was at 10.0 and i didnt expect it to be that bad. Anyhow it's getting tuned saturday and i'm wondering why this turbo would be smoking so bad??? Anyone have ideas?? I'm almost certain i didnt miss any sensors but may have, if so anyone have an idea to that as well??
03sonicyWrX is offline
post #2 of 7 Old 06-03-2010, 09:41 PM
Smoking as in on the surface or out the tailpipe?
Yeah definitely don't run the car without a tune and larger injectors. The ecu still thinks you have smaller injectors in it and keep the same pulse, but it's a bigger injector, so the same pulse on the injector yields more fuel, hence the super rich idle.
post #3 of 7 Old 06-03-2010, 10:04 PM
Who is tuning it? Nvmd the rest...i read your profile.
post #4 of 7 Old 06-03-2010, 10:12 PM Thread Starter
It's smoking on the surface of the turbo, Smoke out of the tailpipe looks to be normal, i've went over my oil feedline/drain lines and it looks perfect. And as far as tuning as long as i figure this turbo out precision tuning in jersey will be tuning it. Well unless you guys know of anyone else closer to eastern PA that tunes the UTEC
post #5 of 7 Old 06-03-2010, 11:04 PM
UTEC....I can't say that I do. I know CBRD Speedfactory does Cobb and O/S tunes. Sh!t, I forget the name of the place in lancaster that does the O/S tunes. I believe the guy's name that runs the place is Ricky or whatever. My one friend went there because it was cheaper than CBRD.
post #6 of 7 Old 06-05-2010, 12:58 PM
squires84 is an unknown
What color is the smoke sir?
I had the same problem and it was the water line to the turbo.
put a new clamp and no more smoke.
squires84 is offline
post #7 of 7 Old 06-06-2010, 08:47 PM Thread Starter
All under control It was just excess oil burning off the turbo, Got the VF30 setup running and WOW! Feels like a whole new car, and i actually read up on tuning the UTEC and tuned it myself and it is pretty much perfect! Thanks guys
