Help me out here - Subaru WRX Forum
post #1 of 8 Old 03-01-2005, 01:41 PM Thread Starter
Help me out here
Ok so i just bought an Aspen White WRX and i got a UTEC, upipe, turbo back, bov.
Now i want to get a FMIC but from what i see, a FMIC and the stock turbo will create a lot of lag. So im thinking of upgrading my turbo as well, however i dont have the money to do internal engine work as well. What kind of turbo upgrades can I do that will keep my stock engine from blowing up? Also what kind of boost should i be running with the turbo you suggest and what kind of fuel?
Another thing i was thinking of is keeping the stock turbo. Are there any FMIC that will not create a lot of turbo lag? Also what about a TMIC? Everyone says heat soak sucks, i personally dont fully understand what heat soak is.
I am kind of leaning towards keeping the stock turbo, so any suggestions would be much appreciated.
AspenWRX is offline
post #2 of 8 Old 03-01-2005, 02:23 PM
Cosmo's Avatar
Images: 15
Any of the smaller FMIC's will be fine with the stock turbo. In fact, something like the Hyperflow would be fine. I had a stock turbo for a little while with my FMIC, and while there was some lag, it wasn't bad. Just slightly more than when I had a bigger TMIC.
If you want a bigger turbo, be sure to upgrade your fuel pump and injectors as well.
Cosmo is offline
post #3 of 8 Old 03-01-2005, 05:45 PM
Ian
Ian's Avatar
Send a message via AIM to Ian
Heat soak is when the intercooler gets really hot and can't cool the air going into the engine fast enough, it will make your car run funny for a short time until you start going again. This pretty much only happens in the summer.
If you go to Gruppe-s.com you will see that they have turbo up-grade packages that will work for you and you wont have to do internals (VF34 OR VF22 turbo up-grade) then you can do a good top or front mount.
Ian is offline
post #4 of 8 Old 03-01-2005, 06:54 PM Thread Starter
if i go with the VF34 upgrade, what kind of boost should i be running on it, also what would that do to me HP wise? Also would i have to upgrade the clutch/flywheel as well?
AspenWRX is offline
post #5 of 8 Old 03-01-2005, 07:04 PM
IBAUCLAPlaya's Avatar
You could probably run 18-19 psi on that turbo w/ a decent tune and be right around 300 whp. No clutch/flywheel is needed.
IBAUCLAPlaya is offline
post #6 of 8 Old 03-01-2005, 07:07 PM Thread Starter
ive heard rumors of the stock WRX motor and tranny only be able to hold like 280 whp, this true?
Also, what is a good intercooler to get for something like this other then the APS one, too expensive for me. I was thinking maybe the Blitz kit?
AspenWRX is offline
post #7 of 8 Old 03-01-2005, 07:32 PM
i have the TXS FMIC v2 and a stock turbo.
full boost at 3214 rpm
Antyoo is offline
post #8 of 8 Old 03-02-2005, 07:37 AM
Cosmo's Avatar
Images: 15
No. I know of several WRX's holding 350-375 whp on stock internals.
Get either the Perrin, Hyperflow, APS, or MRT intercooler. Most of the others (Blitz, Greddy, Injen) are poorly designed. The Blitz and Greddy don't include bumper beams, so you'll have to hack your stock one.
Cosmo is offline
