help with a blow off valve - Subaru WRX Forum
post #1 of 6 Old 01-13-2006, 08:34 PM Thread Starter
dj'swrx2003 is an unknown
i have a blow off valve and i hear nothing but fluttering unless i damn near red line the car. i have a blow off valve that has a turn knob on the top of the valve it dosent use washers how do i adjust it? it also connects to the stock hose that went to the other valve
if it matters i have a ingen short ram on the car and a magna flow down pipe, and exaust???
dj'swrx2003 is offline
post #2 of 6 Old 01-13-2006, 11:21 PM
imbeterthanu's Avatar
imbeterthanu is an unknown
is it the forge BOV? i should have came with differnet spring adjustments.
imbeterthanu is offline
post #3 of 6 Old 01-13-2006, 11:35 PM
9d2TSi's Avatar
What kind is it?
Try turning it out and then start turning it back in until this problem goes away. Small turns (less than a full one each time) should fix your problem.
9d2TSi is offline
post #4 of 6 Old 01-14-2006, 09:02 AM Thread Starter
it's a gfb???? a friend of mine totled his sti and gave it to me for free the only reason i took it is because it bolted right in the intercooler using the stock holes; i didn't have to custom make anything
post #5 of 6 Old 01-14-2006, 09:58 AM
ManicsWrX's Avatar
ManicsWrX is more helpful than not
Take the top off make sure the spring is not stretched or worn. Should be spacers also, depeding on that model I would look into that online and check. Maybe turn it to adjust it....sounds way to tight
Chris- ▼SbiΣ Mi▼
242 AWHP / 318 TQ
ManicsWrX is offline
post #6 of 6 Old 01-14-2006, 11:50 AM
9d2TSi's Avatar
Some interesting reading.
http://www.gofastbits.com.au/index.p...tion=tech_info
9d2TSi is offline
