helix vs bosal dp HELP!!!! - Subaru WRX Forum
post #1 of 17 Old 10-30-2005, 10:59 PM Thread Starter
latinWRX's Avatar
latinWRX is an unknown
I'm not sure which to get. Helix catted or bosal. The helix has a highflow and is 3in all the way which makes me think that it is better, but it is a lot louder (i think). On the other hand, the bosal is a lot cheaper and is not as loud, but it uses the 3rd cat which makes the exhaust change to stock diameter which i think it makes it less powerfull than the helix. So gimme ## advice/choice. I guess what I really wanna know is: Is the difference (if any) between them noticeable (assuming the helix gives more)?
Thanks
"Many people have a good aim in life; most never pull the trigger."
latinWRX is offline
post #2 of 17 Old 10-31-2005, 06:45 AM
gingertooth is an unknown
i have the invidia catless. buy the helix. nicer design and will sound nicer as well. my friend has the bosal and it doesn't pull as hard as mine nor does does it sound as nice.
gingertooth is offline
post #3 of 17 Old 10-31-2005, 07:42 AM
WRXtreme's Avatar
If you plan on getting a 3"catback get the Helix. If you are going to keep everything stock from the downpipe back then you will be able to get away with the Bosal.
WRXtreme is offline
post #4 of 17 Old 10-31-2005, 10:57 AM Thread Starter
latinWRX's Avatar
I'm really more concered with the power differences. Also, will the sound be sorta "can-like", taking in consideration that I will be using the stock muffler (eg. stock resonator) for a much larger exhaust flow??
latinWRX is offline
post #5 of 17 Old 10-31-2005, 11:35 AM
knot04 is an unknown
Send a message via AIM to knot04
IMO the COBB catted down pipe is the best catted down pipe money can buy. its a full 3" with a true high flow cat, and the cat is mounted further down stream of the turbo than the Helix. it is a little pricy, but it is the one that im going to buy.
knot04 is offline
post #6 of 17 Old 10-31-2005, 02:48 PM
GetUpInDer's Avatar
GetUpInDer is an unknown
If power is your biggest concern, the bigger the better. More flow = more hp, who cares who makes it no one is gonna see it any way. Unless you have strict emission laws there is no reason for a cat, and with out the cat a pipe is a pipe no matter whos name is on it.
GetUpInDer is offline
post #7 of 17 Old 10-31-2005, 03:58 PM
slug1 is an unknown
hey man, get the helix dp, I have a catted helix dp, helix up, and a stp cat back, and my exhaust note is nice and low and rumbly!!!!
It is a sound that people notice!!
You will not sound like those coffee can hondas!!!!
slug1 is offline
post #8 of 17 Old 11-01-2005, 05:49 AM
you should also consider going catless as well cause if you do some research you'll realize that most of those with the high flow cats are not passing inspection either. why have a cat then?
post #9 of 17 Old 11-02-2005, 10:33 AM
wrxtacy19 is an unknown
get the UP/DP helix combo from gruppe-s spend the extra money its worth it and its a great deal.
I have an invidia and i love it. But never heard anything bad about helix
wrxtacy19 is offline
post #10 of 17 Old 11-02-2005, 01:16 PM Thread Starter
latinWRX's Avatar
Environmentally conscious/friendly And I have that visual inspection part... dont care if it's a bit harder to see than the rest plus I won't get that black smoke like some subies I've seen around here.
latinWRX is offline
post #11 of 17 Old 11-02-2005, 03:50 PM
hondaeater is more helpful than not
+ 1 for the helix
hondaeater is offline
post #12 of 17 Old 11-04-2005, 10:39 AM
Abismo is an unknown
heres what a full helix system sounds like :eek:
http://www.subydude.com/video/video_dump/HELIX.wmv
This i found on www.subydude.com.
sweet sweet sound.
Abismo is offline
post #13 of 17 Old 11-04-2005, 11:39 AM
DEMENTED's Avatar
DEMENTED is an unknown
get the helix...
DEMENTED is offline
post #14 of 17 Old 11-05-2005, 02:15 AM
fastmatt is an unknown
get the helix or invidia..both very well made and high quality
fastmatt is offline
post #15 of 17 Old 11-05-2005, 04:48 AM
bigbadbuddha's Avatar
Images: 15
i'd forget the cats all together. I mananaged to pass emissions catless
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
