Has Anyone Got Samco Hoses - Subaru WRX Forum
post #1 of 6 Old 03-10-2003, 09:02 PM Thread Starter
TrboChgd is an unknown
Question Has Anyone Got Samco Hoses
Has anyone got Samco coolant hoses? Does the set come with ALL coolant Hoses/ Radiator Hoses? ( i saw a set on vivid racing) And are they worth it? From experiance with turbo cars, anything ruber under the hood gets throughly cooked. I was thinking of changing over to all silicon hoses.
TrboChgd is offline
post #2 of 6 Old 03-11-2003, 07:20 AM
IMPREZvWRX is an unknown
Send a message via AIM to IMPREZvWRX
They are mostly for looks, simply to match your Samco IC hoses and turbo inlet if you have them. They offer no advantage in flow, although they will last longer than a standard rubber coolant hose.
Chris
IMPREZvWRX is offline
post #3 of 6 Old 03-13-2003, 03:20 PM
WhatleyWRX is an unknown
IMPREZvWRX is mostly correct. If the SAMCO hoses were the same shape (specifically the Y-Pipe) there would be little to no difference. However, if you look at the plastic Y-Pipe going from the Turbo to the Intercooler you'll notice it has some restriction to it. This creates greater head loss in the piping. You want to lower the resistance as much as possible so the turbo doesn't have to work as hard to spool up. The hose between the throttle body and the intercooler....I have a hard time believing that does anything. The BOV hose, I can't even speculate whether or not that does much.
Every little bit helps, I have them on my car, not sure it was that noticeable. I tried to monitor spoolup and the like afterwards. I'd like to claim it lowers spoolup, albeit a little, however I have no hard data to back that up with.
Whatley.
WhatleyWRX is offline
post #4 of 6 Old 03-13-2003, 03:55 PM
Whatley.
Re-read his post. He was asking about the radiator/coolant hoses.
Chris
post #5 of 6 Old 03-13-2003, 04:06 PM
Ouch, I'd like to rephrase my opening statement.
IMPREZvWRX is correct.
No one said engineers had to be able to read.
Whatley.
post #6 of 6 Old 03-13-2003, 04:10 PM
Much better.
I also have the Samco IC hoses. My stock ones leaked. These hold the boost much better.
Chris
